Hellwig Swaybars
Old Feb 15, 2016 | 11:56 AM
cocot's Avatar
cocot
Hellwig Swaybars
Will the swaybars for the cutaway chassis work ? I see that the ones listed for cargo van are thinner. 1 1/4 vs 1 1/2
Old Feb 16, 2016 | 06:30 AM
JWA's Avatar
JWA
Assuming you're talking about the same general years cutaway front bars would swap out easily enough. Beginning model year 2008 Ford revised the stock front sway bar mounting & attachments but I don't think that affects Hellwig's designs---they were already ahead of Ford in this area.
I use both front and rear Hellwig bars----absolutely love them!
Old Feb 16, 2016 | 09:46 AM
cocot's Avatar
cocot
so, you are using the thicker bars for the cut away chassis?
Old Feb 17, 2016 | 06:06 AM
JWA's Avatar
JWA
It shouldn't matter which one you use for the cargo-only van---I'm saying IF the cutaway was of the E450 or above chassis Hellwig may identify them as such.
Keep in mind the Hellwig front bars for both the E250 and E350 are the same, I believe that to be true for the rear too. I know they say E450 rear bars won't work on the E250/E350's but that's due the axle mounting rather than frame width.
If in doubt call Hellwig's customer service---they're great to deal with.
InmatesRunThePlace
37
Apr 26, 2025 01:55 PM
the_real_zekenator
16
Dec 1, 2015 10:12 AM
POPAJON
May 3, 2014 12:18 PM
Desert-Rat
May 23, 2006 12:43 PM
SGRacing
Apr 15, 2005 08:31 PM
