1978 - 1996 Big Bronco
Shifting linkage problem?
Old Aug 10, 2003 | 02:45 PM
BroncoMTR's Avatar
BroncoMTR
Randomly my Bronco began doing something strange today. It refuses to shift out of Park once started. If I turn the electronics on, but not the engine, it still won't shift. However, if I turn the key some, before the electronics and fuel pump activate, it will shift freely. So I'm starting it in neutral now. Once it's started in nuetral, I can shift freely to and from every gear, except park. If I put it in park it will lock up again. It's irritating. Any ideas?
Old Aug 10, 2003 | 05:15 PM
kd5kuu's Avatar
kd5kuu
The reason you can shift it when the key is only slightly turned is because it is built that way. You might want to check out your brake-shift interlock. It will prevent you from shifting out of park unless the brake is pressed.
Old Aug 10, 2003 | 05:34 PM
3broncocrazy's Avatar
3broncocrazy
Brake light fuse blown? Then must ask y.
Could it be the master cylinder sending unit.
