fuel problem
Old Aug 10, 2003 | 02:38 PM
sosotwo's Avatar
sosotwo
fuel problem
my 96 explorer died today
it will not start
there is no pressure at fuel filter none on the valve at the fuel rail I tried changing the relay no luck
any ideas?
fuel pump sounds like the culperit
Old Aug 10, 2003 | 03:06 PM
Opera House Works's Avatar
Opera House Works
fuel problem
It has a red reset button. You can also pull the electrical connector near the tank and check for continuity on the two heavy wires. Should be the pink/black and black wires. The flow is battery > fuse > relay > inertial switch > motor > ground. And you can always hit the tank first. That can temporarily unstick the brushes in the motor.
tennesseecoalroller0
Jan 1, 2012 03:08 PM
bassproguy07
Aug 20, 2006 09:13 AM
lpbaca
Mar 29, 2005 08:16 PM
state
Oct 26, 2004 08:15 AM
cajunbronco
Jun 16, 2002 09:56 PM
