New injector problems
#31
I received a call from a ford customer service rep yesterday he said That I will be satisfied and happy when I get my truck back and I went by the dealer and my parts came in, things are looking better hopefully ford follows through. I was worried about metal getting into my engine and potentially causing damage to the engine. The mechanic showed me the metal shavings that was in the fuel and I had a very lengthy conversation he's a great guy and is very knowable he eased my concerns. Hopefully I get my truck back soon so I can stop the bleeding and stop losing money, I need my truck to make money and pay my bills
#33
Crystal
#34
Crystal thank you for your help, can you make miracles happen and get my truck back to me by this weekend I'm sure that's out of your hands but worth a shot. They've had 8 days taking it apart and its in a 1000 pieces so I don't want them to rush putting it back together and have to come back because it was rushed, I took some pictures scary seeing my truck in that many pieces being new. Thank you again for your help Crystal.
Thom12, no that's why I want it replaced
#35
Crystal thank you for your help, can you make miracles happen and get my truck back to me by this weekend I'm sure that's out of your hands but worth a shot. They've had 8 days taking it apart and its in a 1000 pieces so I don't want them to rush putting it back together and have to come back because it was rushed, I took some pictures scary seeing my truck in that many pieces being new. Thank you again for your help Crystal...
Crystal
#36
I just left the dealer again and talked to the ford customer service representative that Crystal had call me. The customer service rep said he can't have them replace my fuel pump the dealer tells the ford warranty dep what they find and fords warranty dep tells them what to replace and what not to and the customer can't talk to the warranty dep
#37
So ford doesn't know where the metal shavings came from and tested the fuel, drained the tank and took pictures of the parts and sent the to ford engineering. A lot of work to try to have the issue be out of warranty so I would have to pay for it. All test came back negative and they only want to replace the injectors and fuel line but NOT replace the pump the only part of the fuel system that has any moving parts sounds like ford is just kicking the can down the road. Sounds like ford is taking the cheap way out. If I had bad fuel and I had to pay for it I bet ford would make me replace the hole system exspcially the pump in order for me the keep my truck under warranty.
New truck, ford doesn't know where the metal shavings came from, ford taking a guess and hope replacing part of the fuel system will work and had my truck since February 10th
Ford customer service rep said he will be willing to pay for half the pump and Me or the dealer will have to pay for the other half. So now I have to wait until Monday to see if the GM from the dealer will pay the other half
#38
#39
That's not the point. They will have my truck for over 2 weeks while I'm losing money not having my truck and what if 6 months from now I'm up in the mountains camping with the wife and my pump lets go now I'm stranded with no way to go home and no cell service. Then I have to some how get it towed to the dealer and have them go through this hole process again so they can try to blame it on me because of bad fuel.
I get stranded
I have to find a way to get home
I have to get it towed to the dealer
I have to be with out my truck for another half a month
I lose more money than it would've cost to just replace the pump again not having my truck
They only have to replace a pump that may have been inevitable to fail anyway
Doesn't sound right on a new truck at almost 70K for them to save about 800 does that sound right to anyone?
I get stranded
#40
I get stranded
I get stranded
Ford, and most manufacturers, typically won't go too far out of their way for you. In this case, they are hoping replacing the cheaper parts of the system will allow your truck to make it past 5 years or 100k miles before it fails again. I believe with near certainty if the fuel pump is the source for metal shavings, you won't get too many more miles before this problem arises again...and at that point, the dealer would need to replace everything again, including the pump. Unfortunately when you buy a vehicle, you have to play a game with warranty repairs.
For 2015, the fuel pump pistons were given a special coating which reduced friction and lubrication requirements...this coating should theoretically make the pump less susceptible to failures from poor quality fuel or contaminants. That is why I think it is unlikely your pump is the source of the shavings. I'm not sure where the shavings came from, though, and why they'd even bother to replace the high pressure lines (these can be cleaned)...but I'm not an expert.
Best of luck. I'd be happier if they replaced the whole fuel system if it were my vehicle. Maybe the dealer will help you out.
#41
#43
#45
