Spaced out
Old Aug 10, 2003 | 10:42 AM
Custom 1975's Avatar
Custom 1975
Spaced out
Does anyone know what is the purpose of spacer plates between the carburator and manifold. Do spacers have any effect on performance, or simply just to gain height for linkage clearance ect.??
I have an edelbrock 600cfm installed on an edelbrock performer manifold. I am not using a spacer plate. Should I be??
Thanks
Custom 1975
Old Aug 10, 2003 | 09:40 PM
johnsalterego's Avatar
johnsalterego
Spaced out
Spacers can be used for three purposes; Tune plenum volume to tweak the power curve a bit (as a rule more volume under the carb tends to help @ high RPM, less volume helps torque and throttle response), give clearance for linkages, and/or to isolate the carb from the heat of the rest of the motor. There are two basic types, open and 4-hole. The open ones are usually used for open plenum intakes While the 4-hole ones are for dual-planes like your peformer. Either can be made of phenolic (spelling?) plastic to give some thermal protection to the carb.
As to whether or not you should run one, that question is sure to start a flame war! I run a short phenolic 4-hole one to help keep the carb cooler... but that's just me.
Old Aug 11, 2003 | 01:59 PM
LxMan1's Avatar
LxMan1
Spaced out
I have always had good luck running a 1" 4 hole spacer on my performers. I like the added clearance and it helps keep some heat off or the carb. On dyno reports that I have seen, they actually help low end torque just a tad. The open spacers help top end power.
If you are running good and not having any problems, I wouldn't put one on. I have had one for years and that's why I always use it.
Jimmy
HillBillyBuddha
WTB - Parts & other
May 20, 2013 09:06 PM
Rick_Fury
Dec 12, 2011 05:02 PM
LARIAT 85
Aug 12, 2007 04:14 PM
the law
Apr 27, 2002 02:07 AM
