Stalling
Old Aug 10, 2003 | 04:15 AM
78AZBronco's Avatar
78AZBronco
Stalling
I have a 78 351m Bronco, with a Holley 2300 500cfm 2bl carb. The engine runs fine until it reaches operating temperature, and then it stalls if i accelrate. It will Idle fine. I have a clear fuel filter just before the carb and its dry. I replaced the fuel pump, filter, battery, coil, plugs, wires, cap, rotor, and the ignition module. I have checked all of my vacuum lines to make sure nothing is unplugged. It runs great until it warms up usually 15-20 min. PLz HeLp
Old Aug 10, 2003 | 05:49 PM
danlee's Avatar
danlee
Stalling
I had a similar problem with my 400. It seems to heave been due to plug fouling. That in turn was due to cold plug heat range and low thermostat temp (180). Since I have changed these, I haven't had any problem.
