desktop dyno
Old Aug 9, 2003 | 11:45 PM
knocturnal's Avatar
knocturnal
desktop dyno
if it isnt to much trouble.... could some one send the proper specs of a stock 300... EFI... instead of me sitting here playing with a 301.6 ci 6 cylnder making 600 hp at 8000 rpm... LOL
Old Aug 10, 2003 | 01:52 AM
MEPR's Avatar
MEPR
desktop dyno
im perty shure a stock EFI 300-6 is about 120hp and 210 lbs ft. Not shure about at what rpm though.
Old Aug 10, 2003 | 10:07 PM
knocturnal's Avatar
knocturnal
desktop dyno
its more like 150 at 3500 and 265 at 2 thousand something... but i need to know like what are you stock stats to build off of
Old Aug 11, 2003 | 05:19 PM
chuckman's Avatar
chuckman
desktop dyno
theres a thread around here with the airflow and cam files linked to, entitled "bluerace cam." its fairly recent, so should be easy to find.
i know compression is 8.7, air intake is 300cfm, and exhasut should be small-tube headers with mufflers. thats all i can remeber off the top of my head. itll give a very accurate rep, with the 265lb/ft at 2000 and 150hp @3500.
Old Aug 11, 2003 | 06:35 PM
kevin122's Avatar
kevin122
desktop dyno
4" bore 4" stroke, 1.75 intake 1.58 exhaust, 8.5 compression, 300cfm single plane, stock man with muffler, seat to seat .249 int. .249 exh., btdc 12.0 abdc 62.0 bbdc 66.0 atdc 10.0 125hp @3500 235ftlbs @2000 as close as i could get when i started
Old Aug 12, 2003 | 10:13 PM
knocturnal's Avatar
knocturnal
desktop dyno
thanks alot exactly what im lookin for
Old Aug 13, 2003 | 08:55 PM
Silver Streak's Avatar
Silver Streak
desktop dyno
.249 is the lobe lift, the valve lift with a 1.6 rocker is .398. .398 is what you want to enter in DD.
6t6merc
Oct 7, 2002 07:49 PM
6t6merc
Feb 13, 2002 03:20 PM
6t6merc
Dec 10, 2001 09:50 AM
6t6merc
Oct 24, 2001 07:46 PM
6t6merc
Oct 22, 2001 12:56 AM
