ecu part number help please
Old Feb 5, 2016 | 01:54 PM
Binkowski's Avatar
Binkowski
Hi,
I believe I have finally diagnosed my no start issue to a bad ecu. Took the ecu out but I can't read the part number on order to order a replacement. Hoping subford or someone else can help me find it through the calibration number on the door jam.
So the calibration on the door jam is 4-54E-R10 and this is on my 95 F150 Subcab 4x4 5.0L 4R70W
Thank you for the assistance. Really need this truck to start when I turn the key.
Old Feb 5, 2016 | 05:15 PM
RIKIL's Avatar
RIKIL
I don't think the door jam will have any info to help with that. If you can't find the part number, you can get an equivalent. The ECUs are made for a motor/trans match so you don't need the specific part number, just one to match those specs.
Old Feb 5, 2016 | 05:21 PM
rla2005's Avatar
rla2005
Subford has the ability to cross reference Calibration codes to PCM part numbers.
Old Feb 5, 2016 | 05:57 PM
RIKIL's Avatar
RIKIL
Will the GLO2 work?
File Type: pdf
Old Feb 5, 2016 | 09:46 PM
rla2005's Avatar
rla2005
1995 F150 w/5L and 4R70W is most likely a MAF truck. GLO2 is not going to work.
Old Feb 6, 2016 | 12:01 AM
timbersteel's Avatar
timbersteel
I have the exact truck, HUG2 is the PCM.
I've uploaded pics of the PCM for you that I took today when I had mine out.
Hope this helps.
Mine is a '95, 302, 4wd, Ext Cab, Eddie Bauer, 4R70W
Old Feb 6, 2016 | 08:22 AM
subford's Avatar
subford
X2 ^^
That is my truck also.
HUG2 Engineering # F4TF-12A650-APC
But the 4-54E-R10 number does not cross to that and it looks like Ford did an up grade on that PCM.
The cross shows F4TF-12A650-APB for the Engineering # and F4TZ-12A650-APB for the part number or service number.
Note Ford never puts a part number on a part because they change on up grades. The number on a part is only an Engineering drawing number.
Old Feb 6, 2016 | 12:42 PM
Binkowski's Avatar
Binkowski
thank you
Thank you so much timbersteel and subford. This is hugely helpful. Now to choose the right place with a lifetime warranty.
Mr. Rogers
Jun 10, 2018 08:04 PM
Hibiscusmile
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Feb 4, 2014 06:49 PM
2006powerstroke90
Nov 27, 2011 09:55 PM
