High Delta ?
Old Feb 4, 2016 | 08:37 PM
mtnxtreme's Avatar
mtnxtreme
High Delta ?
My truck is running pretty high Deltas. The highest I've seen is ECT 160 and EOT 210. Most of the time my ECT is below 150, which seems pretty low to me, but my Deltas are around 40-50 at all times. I fill my Degas to the lower mark, and it always seems to blow abt an inch lower thru the cap, but it will stay there. I also notice some bubbling in degas bottle when idling. No white residue on cap, just seems to blow out that one inch of bottle level, which takes abt. a quart of coolant to refill. Also when I let off the throttle quickly I hear a kinda rattle thru the turbo, but the turbo spools up nice, if I let off smoothly no rattle. Truck runs excellent, plenty of power, starts easy. Am I looking at a new cooler, anyone riding around with deltas this high? I did my own oil cooler set up, have a thread on here detailing it. I guess I can do another if need be. I wonder if anyone ever ran one of these with no oil cooler, always wondered why it needs one, plenty of big V8 out there, no cooler at all ?
Old Feb 4, 2016 | 08:50 PM
KIDkiser's Avatar
KIDkiser
Your ect is away to low.should be around at least 188 to 190 I would change the thermostat,and check the temps again
Old Feb 4, 2016 | 08:53 PM
navistarnut's Avatar
navistarnut
Get a new tstat in there for starters. You are burning fuel needlessly as the engine is trying to warm up. You should be at a minimum 185.
6.0 is much happier and efficient running up over 185 and beyond.
You should not be seeing bubbling in the degas.
Old Feb 5, 2016 | 07:39 AM
mtnxtreme's Avatar
mtnxtreme
You know I was just thinking this, this morning, that the ECT is not getting hot enough and a thermostat should even thinks up a little, and then see what my Deltas are. Best part about this, is I flushed my system last week, so would have been a good time to do the stat, now i gotta drain her down again ugh. OK I'll give it a shot. Any ideas on the fluttering sound when letting off throttle. And what causes bubbles in Degas, possibly purging air , since I just drained it ?
Old Feb 5, 2016 | 08:24 AM
KIDkiser's Avatar
KIDkiser
Just drain about a gallon out to change thermostat.as far as the bubling goes,could be a bad egr cooler caused by bad oil cooler,could be head gaskets,I recently had bubbling temp spread was normal but the degas cap was venting and my heat wasn't working very well,so now I'm doing head gaskets.
Old Feb 5, 2016 | 12:29 PM
NotURMailman's Avatar
NotURMailman
Like everyone said, get a good t-stat in there and then check your delta. You may have no problem other that a stuck open thermostat.
Old Feb 5, 2016 | 01:42 PM
mtnxtreme's Avatar
mtnxtreme
I picked up a thermostat at Carquest says 89/104 Celsius. Whats the proper temp to be running? 104 translates to 214 degrees ? Seems hot ?
Old Feb 5, 2016 | 02:31 PM
Mike189677's Avatar
Mike189677
oe t-stat is 192 kind of late now but you might want to get a motorcraft t-stat people haven't had much luck with the part store ones people have been liking the mishimoto that is a 200 degree. At 214 your fan will be running and google says it's even hotter 104 c = 219.2 degrees
Old Feb 5, 2016 | 03:33 PM
silverbullet6oh's Avatar
silverbullet6oh
Originally Posted by mtnxtreme
My truck is running pretty high Deltas. The highest I've seen is ECT 160 and EOT 210. Most of the time my ECT is below 150, which seems pretty low to me.
Replace the thermostat with a FURD OEM, or a Mishi (which I don't recommend, but others seem to love).
Please tell us what noise it sounds like, a rattle to me is much more different than a flutter.
I believe a flutter is from the turbo not having a waste gate.
I know I could really hear my turbo fluttering before cleaning it, made a "huffa, huffa" or "cuff, cuff" noise. I am going to soon find out if it helped.
Return it, get the OEM.
Old Feb 5, 2016 | 05:39 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Oil cooler is needed because of the high pressure the fuel injection system needs to see during acceleration. The HPOP makes pressure around 4,000 psi during high fuel demand. That makes a ton of heat in addition to the normal heating the oil sees.
Old Feb 5, 2016 | 08:21 PM
mtnxtreme's Avatar
mtnxtreme
You hit the noise right on the head, when I hear it, it reminds me of a door swinging that rubs ? Maybe I'll try nailing the **** out of it a few times if that don't work, I'll clean it.
Old Feb 5, 2016 | 10:02 PM
WatsonR's Avatar
WatsonR
the turbo relieves pressure thru the intake, called a turbo fart. Letting off quickly makes it relieve excess pressure.... mine does it and yours should to. If it didn't, that would indicate that the vanes are stuck... I make sure mine does it at least once a week... stab the throttle and then let off fast... no flutter or huffa, huffa... needs cleaning.
VGT turbos have no blow off valve, why they make that noise. Blow off valves do just a big hiss when relieving pressure, our VGT farts.
Old Feb 5, 2016 | 10:06 PM
silverbullet6oh
Yeah! What he said!
Don't listen to me I had it all bassackwards. Well, except I had the waste gate info right.
I can't believe my trucks a fart sniffer.
LMAO!!!!
Old Feb 6, 2016 | 05:11 AM
mtnxtreme's Avatar
mtnxtreme
hahaha it just sounds weird, this is my 3rd 6.0 and the other 2 never made that noise, and one I even cleaned the turbo, and they ran beautiful, weird !
Old Feb 10, 2016 | 09:46 AM
mtnxtreme's Avatar
mtnxtreme
OK installed the new thermostat running 186 ECT and 220 EOT pretty consistant give or take. 35 degree deltas ! I've seen it spike to 40 on long uphill pulls and its winter. My EGR is deleted so should be safe for a lil while. My cold soak shows the EOT to be act. 5 degrees higher than ECT. Guess I should start gathering parts to do my external oil cooler. Alreday have a E series oil cooler cover just gott weld in some fittings. Had very good luck with the system I put together and did 2 more on friends truck, 100,000 trouble free miles on one of the systems so far, just a little proof to those who say it cant be done for around $500 - $600 in parts reliably and need to buy the $3000 bulletproof system.
