problem reading trouble codes
Old Feb 4, 2016 | 05:57 PM
lowrider50's Avatar
lowrider50
I am trying to get the trouble codes from my 95 5.8. I brought the engine up to operating temp. and turned off all the accessories. when I scan it keeps on telling me to turn off the air conditioner. Anybody know why this is happening and what would be telling the computer that the A/C is on?
Old Feb 4, 2016 | 07:42 PM
subford's Avatar
subford
That means you failed to hold the clutch on the floor during the self-test.
Old Feb 4, 2016 | 08:31 PM
lowrider50's Avatar
lowrider50
I should have mentioned the truck is a automatic
Old Feb 4, 2016 | 08:53 PM
subford's Avatar
subford
Then it sounds like you may have the wrong PCM Computer in your truck.
What kind of automatic do you have (AOD, C6, 4R70W or E4OD)?
What code are you getting and what test is it from (KOEO, CM or KOER)?
Old Feb 5, 2016 | 07:27 AM
lowrider50's Avatar
lowrider50
I have the E40D. I tried KOEO and KOER. It seems it won't scan because it thinks the A/C is running.
Old Feb 5, 2016 | 07:39 AM
danr1's Avatar
danr1
What are you trying to read the codes with, what model code reader?
Old Feb 5, 2016 | 08:16 AM
lowrider50's Avatar
lowrider50
I am using a Autoxray 6000
Old Feb 5, 2016 | 08:23 AM
danr1's Avatar
danr1
Yea that's probably the problem to advanced of a reader.
Get one of these, (example only can be had for under 30 bucks locally)
Product Detail
Old Feb 5, 2016 | 12:25 PM
lowrider50's Avatar
lowrider50
I still don't know why the PCM is getting feedback that the A/C is running. Maybe I'll try jumping the terminals where the reader plugs into first and see if that works and if it does I will get a reader as you suggested.
Old Feb 5, 2016 | 12:31 PM
subford's Avatar
subford
I hope you are talking about grounding the single (STI) wire.
Old Feb 5, 2016 | 05:25 PM
lowrider50's Avatar
lowrider50
That's what I'm talking about.
kfcoltn
Aug 29, 2016 11:34 AM
subford
Oct 18, 2015 10:20 AM
RIKIL
Oct 2, 2015 09:00 PM
Jason8705
Nov 16, 2004 12:06 PM
Craze
Jul 12, 2004 02:06 PM
