Hey, you were on I-395, so your in CT I take it ??
I use that highway many times myself. When I had my truck it was 55K and it hit that when I was rolling through the local supermarket parking lot. Its amazing we know where all the major millage markings took place
Original engine, original T-19 (with the third gear synchro pretty much totally gone) tranny, had 2 clutches replaced, one flywheel, one injector pump (probably will need another one soon), about 4 injectors, one radiator.
The original radio still works, & the A/C still blows cold.
Hit head-on while stopped in a parking lot by a Cavalier wagon going ~25MPH. So glad it has a BIG push bumper (I-beams welded together). I drove the truck back, the Cav left on a Fuso rollback.
Rear-ended by an idiot in an Accord--stopped, she hit the stinger at ~35MPH. She said she "didn't see those small taillights". (To which I responded: "Well what about the BIG ****ING TOW TRUCK?!")
Did 40 miles towing a Stepvan. No, that wasn't anywhere near legal. Nor anywhere near smart. Nor was I the one who did that.
Highway road construction, pavement was milled down to put on a fresh layer of asphalt. Well, they didn't warn anybody that there was now about a 2" rise to the bridge expansion joints, didn't paint them orange (which they usually do), no "BUMP" signs...NOTHING. Running empty, I hit that bridge at about 68MPH...if I didn't get the front end a foot off the ground, I'll eat my toolbox. Did I mention all tires running at max (80) psi? I looked the entire front end over on a lift. Total damage: 2 missing weights on the left front wheel. Coffee on the floor. All my paperwork covered in coffee. Coffee in my boot (fun). I keep my coffee tightly covered now.
Pulled a loaded Ford F-Super Duty dump truck out of a ditch...no, stupid, you CANNOT take a 30MPH posted turn at 45 with a box full of topsoil in the rain! That took some creativity--and about 2 hours. Good thing he didn't need the hook--the 86 is tough, but not THAT tough!
Thanks Jarlaxle I laughed for 10 minutes when i saw this lol
Not that we're not busy, we just spread the miles out a bit:
1974 GMC C-35 rollback (292 I-6, 3 on the tree): 469,000 (backup truck)
1987 GMC R-35 wheel-lift/sling (454/TH400): 388,000
1986 F-350 wheel-lift/sling (6.9 IDI/4-speed): 501,000
1992 F-350 wheel-lift (460/E4OD): 296,000
2001 F-550 rollback (entered service 3/2003, PSD/6-speed): 110,000 (!)
1972 F-800 HD rollback (361FT/Clark 5-speed): Fates only know how many times it's turned over
Replaced by the 550: 1992 Mitsubishi Fuso rollback (diesel/auto): 297,000
Also in service, though not very often...
1968 Chevy C-30 sling, 350/SM465, somewhere north of 250,000 miles, just put back on the road after sitting 4 years due to going head-on with a Mercedes S320.
The 74 is on its second 292 & fourth clutch, the 87 had its 454 replaced at ~280K, the 92 cooked its trans at 210K, the 86 is on its third clutch & second set of doors (road salt sucks!), the 550 will probably get a new clutch this winter. The F-800 is on at least its third set of doors, & second cab (salt sucks).
The Fuso ate 3 trannies, 2 air compressors (air brakes), & no less than 4 radiators (quite a pain in a COE) between 90K & when the boss finally dumped it. I think he almost cried when he saw the trade-in value.
axle, maybe we should start a thread on wrecker bloopers , we have the same stupid crap happen here in Missouri. Ive run a class 8 wrecker for 7 years now along with a 1 Ton
