Sponsored by: Auxito
How does 5.4 valve train work
Old Feb 2, 2016 | 07:20 PM
Dave042's Avatar
Dave042
Question How does 5.4 valve train work
I cannot find much online about how the 1997-2003 5.4 valve train is designed or works. I know it is a single overhead cam, and there are 2 valves per cylinder, but does anyone out there have a good schematic or diagram of the valve system? Are there hydraulic valve lifters? I have a tapping noise on my 2002 5.4, that is not very loud, but enough to be noticeable. I used an engine stethoscope the other day to listen where it was coming from, and I heard it the most on the passenger side towards the back..last 2 cylinders basically. The front of the valve covers sounded fine, so I think the timing chain is good. and the spark plugs are new and I made sure I tightened them good. What could be the cause?
Old Feb 2, 2016 | 07:54 PM
kd4gij's Avatar
kd4gij
Did you torque the plugs to 28ft lbs.? That is what ford recommends now.
does this help?
http://www.autopartswarehouse.com/se...0+Cam+Follower
Old Feb 2, 2016 | 08:08 PM
Dave042's Avatar
Dave042
does this help?
https://www.rockauto.com/catalog/raf...ktemplate=true
It was about 30-35 ft. Lb. I used motorcraft plugs.
Old Feb 2, 2016 | 08:21 PM
85e150's Avatar
85e150
google for more:
http://www.ramscyl.com/images/ford54.gif
steager_94
2004 - 2008 F150
Nov 17, 2016 04:40 AM
sbeamer
Modular V8 (4.6L, 5.4L)
Nov 7, 2013 07:56 PM
Shernius
1997 - 2003 F150
Aug 10, 2013 04:14 PM
MWH615
Mar 2, 2010 11:32 AM
tjc transport
23
Jan 1, 2008 09:49 AM
