400 update
Old Aug 9, 2003 | 08:36 PM
Coondawg's Avatar
Coondawg
400 update
Finally fired off the 400 after quite a while of rebuilding. Hit on the first spin.
After driving around for a few miles, I stopped for gas and noticed coolant drizzling from the radiator. Had three pinholes. Ended up replacing the radiator with an aluminum one from Summit. It is the same length and height but 1/2 inch wider. Has two 1 inch wide cores and all welded seams. It works very well, cooler than stock by a bit.
I took it to the rifle range last weekend and went the long way. I got about 12mpg over an 80 mile distance. Not bad considering I averaged 70mph and the setup of the truck. Needs a little more tuning.
Here's what I have: '80 F100 stepside 2wd, 400(1977) bored .040, .484-.510 cam, 9.5:1CR, Weiand intake, Holley 600cfm carb, roller timing chain, long tube headers, electric fuel pump, soon will have roller rockers and MSD ignition; FMX trans with large cooler; 31X10.50-15 tires; 9" limited slip-2.75 gears.
Old Aug 9, 2003 | 10:51 PM
Matts72's Avatar
Matts72
400 update
Dang it I want that rear end!!!!!!
GoinBoarding
89
Feb 23, 2020 06:27 AM
400v8f250
Jul 11, 2016 06:03 PM
losio
Jul 8, 2016 06:43 PM
POPAJON
Jul 17, 2014 04:56 PM
Stinky1
Dec 14, 2012 11:10 AM
