Ford axle decoder!
Old Feb 1, 2016 | 02:47 PM
The_Drew's Avatar
The_Drew
Ford axle decoder!
Hey guys I found this website that shows all the info for ford axles I thought it would be cool to share with y'all and maybe even get it stickied so everyone can use it and figure out what they have. Cheers!
Ford Rear Axle Assembly Identification - Page 17 - FORDification.com
Old Feb 2, 2016 | 05:54 PM
ncranchero's Avatar
ncranchero
That has come in handy a time or two for me.
Old Feb 3, 2016 | 09:16 AM
Chuck95642's Avatar
Chuck95642
You are The Man!!!
Old Feb 11, 2016 | 04:02 PM
Pappawheely's Avatar
Pappawheely
I have a unique tag off a 97 cab and chassis; can someone help with this:
top row: S F6TS - BA
bottom row: 10 10.2 7J25
Old Feb 11, 2016 | 06:02 PM
madpogue's Avatar
madpogue
Is the "10 " on the bottom row right next to the hole that the cover bolt goes through? If so, I'd be willing to bet that means it's a 4.10 axle. I've seen a couple where the tag was likely broken off at the hole when the diff was serviced, then a new hole poked in the tag in order to reinstall it. The new hole obliterates the first character or two on the tag. So I'm thinking your tag originally had "4 10..." or "4L10", which would be 4.10 open diff or 4.10 limited, respectively.
Old Feb 11, 2016 | 10:16 PM
The_Drew's Avatar
The_Drew
[QUOTE=Pappawheely;16034724]I have a unique tag off a 97 cab and chassis; can someone help with this:
bottom row: 10 10.2 7J25[/QUOTE
Through my research I have discovered:
Top row: the s would stand for sterling
Bottom row: missing the 4 but it woul be 4.10 gear ratio 10.2 would be gear ring size and the rest would be date
That's my result, no promises on accuracy. Found this info on powerstroke nation forum hope it helps
Old Feb 12, 2016 | 06:48 AM
Chuck95642's Avatar
Chuck95642
Found out I am running 3:08's per the Vin Decoder here.
jwmghf
Jul 6, 2015 02:04 PM
Opossum
1997 - 2003 F150
Apr 11, 2009 05:14 AM
zeaga
Jun 19, 2007 04:45 PM
RTM
Mar 27, 2004 02:32 PM
Ford_Six
Oct 30, 2002 09:30 PM
