Correct Distributor Setup 1951 Flathead V8
Old Jan 31, 2016 | 04:53 PM
hulleywoodworking's Avatar
hulleywoodworking
I just sent this over to Bubba's and thought it would be a good general information post for here. I'll add his response when I hear from him.
"So here is what I've got:
1951 Ford F1 239 Flathead 8
Motor completely rebuilt this year-bored .030 over, otherwise all stock internals
Edelbrock 1107 intake manifold with Edelbrock 1405 4 bbl carb
MSD 8200 Blaster Coil
Petronix 1283 Ignitor
Aluminum Loadmatic Distributor (cleaned, new bushings and drive gear)
3 speed column shift transmission
3.92:1 rear end
Stock exhaust manifolds with dual exhaust
The motor was assembled, tuned, and run by the rebuild shop, so I know that everything works. I want to know if this is the best distributor setup for this truck as a daily driver. Looking for a trouble free reliable setup. What do you suggest?"
Old Jan 31, 2016 | 07:07 PM
tinman52's Avatar
tinman52
Welder User
I'll guess he recommends his converted Chevy distributor for flatheads. The lodamatic ain't gonna work right with the 4 bbl no matter what trigger you put in it.
Bubba's chevy units work great, and really wake up a flatmotor. I have one on mine...
Old Jan 31, 2016 | 08:12 PM
green53's Avatar
green53
Ya the loadmatic needs carb venturi vacuum from a holley 94 instead of manifold vacuum to run the advance, so without a stock carb they won't have advance.
1954wrecker
Jun 20, 2018 10:35 PM
bergieb
Jan 25, 2009 02:55 PM
MARC
18
Apr 1, 2004 10:36 PM
cortez
Mar 7, 2004 04:39 PM
WRC
Bronco II
Dec 2, 2003 11:37 PM
