I need help please!
Old Feb 8, 2002 | 04:18 PM
ealid's Avatar
ealid
I need help please!
Hi. I hope someone can help quickly on this one. How do you remove the inside door panel of the front driver's side door? I unscrewed all of the visable screws and it is still solid. I yanked on the door handle to open the door way to hard and it broke. I think it came apart inside. It just hangs now. I don't think the parts are broken, just came apart somehow. Anyway, how do I get access to fix it? Much Thanks.
Ed
BTW- It is a 1994 F-350 Crew Cab. I have also been to my local Napa Auto Parts store and they were a big help (sarcasm)! They didn't have any help manuals that I needed in stock. So, I went to the local library and the ones I needed were checked out. I have four of the plastic 'pins' popped, but how many more are there? I can see one, but it is in the middle of the door panel and I am worried I will break the thing in two if I pry it anymore. I could use any help right now. Thanks again.
Old Feb 8, 2002 | 05:55 PM
GammaDriver's Avatar
GammaDriver
I need help please!
Lessee ehre - the last I counted on my 1993 was about 8 push-pins, the screw down in the door handle, the screw at the top under the vent window, and I'm nearly sure there were one or two more screws toward the bottom.
You'll pull the panel from the bottom, working up to lift the lip over the bottom of the window ledge.
Feel free to break the push-pins. They normally break for everyone, anyway. While not as cheap as they should be, both Ford and NAPA (if you really want to go there again) sell the exact same plastic replacement push-pins. They just slide into place on the door panel, then push into the door again.
Old Feb 8, 2002 | 06:47 PM
edenroadmaster's Avatar
edenroadmaster
I need help please!
hivoltj
Mar 9, 2015 12:05 PM
golfnut324
Dec 26, 2010 10:15 AM
vze2sgxa
Jul 13, 2009 10:39 AM
darinkexplorer
Feb 24, 2004 10:06 AM
