Sponsored by: Real Truck
Lock cylinder
Old Jan 31, 2016 | 02:59 PM
93F250's Avatar
93F250
Lock cylinder
I changed the shift tube in my Excursion today. I'm trying to put the key switch back in. It will go in and rotate fairly hard. I can not get the key to release. When I hook the battery back up, everything functions as it should but it won't start, the key won't release and it still turns hard. The dash lights come on and such when the key is turned to run. I tried a different key with the same results. Everything looks good. Any ideas?
Old Jan 31, 2016 | 05:03 PM
93F250's Avatar
93F250
Updated info
I guess the shift lever wasn't quite in park. Now I can remove the key. It still goes a little dry but it is manageable. It still won't start. Battery connections are tight. No codes other than 2 ABS codes but that isn't anything new. Now when I remove the key, it dings at me when the drivers door is open. No other doors do this.
mutantsquirl
Feb 22, 2023 11:32 PM
traildad
1997 - 2003 F150
Nov 30, 2017 08:29 PM
75_92_95
1978 - 1996 Big Bronco
Aug 19, 2016 10:18 PM
1988-Ranger
1983 - 2012 Ranger & B-Series
Jun 7, 2004 08:00 PM
Trail_Rider
Dec 24, 1999 11:36 AM
