Long cranking when warm
Old Jan 29, 2016 | 01:21 PM
EddieEX10's Avatar
EddieEX10
I have read a numberof threads on this issue but wanted to run the situation by this group as asanity check.
Some informationabout the truck
  • 2004 Excursion, Motor has a December 2003 built date listed on the valve cover
  • Bullet proof complete by Hallas performance just prior to Mike's passing (3 years ago). ARP, EGR, Oil Cooler, lifters, etc…
  • Newer batteries, DC amp 185 alternator, newer starter, she cranks hard and fast…
  • ~230,000 miles
Here is thesituation:
  • Starts good and fast when cold, even subzero temperatures.
  • She cranks long and barely catches if I make a short stop at a store or restaurant. A few hours later or the next morning is fine…
  • I found the following codes:
    • P2284 - Injector Control Pressure Sensor Circuit Range/Performance
    • P2291 - Injector Control Pressure Too Low - Engine Cranking
    • P0528
  • I took her into the local Ford Dealer for diagnosis and here's what they reported.
    • ICP tests good and has the latest pigtails.
    • They reported a leak in either of the following.
      • Oil injection pump
        • Estimate of 8.5 hours to repair.
      • Under the Valve Cover Gasket.
        • Estimate of 3.5 hours to repair.
So here're thequestions I have.
  • Does this diagnosis sound appropriate? Is it reasonable that they do not know which area is causing the problem?
  • Are the hours reasonable estimates for the repairs?
  • Assuming I go ahead with these repairs, is there anything else I should have them look at while they're in there?
I appreciate anyadvice or experience you can share! This forum is an awesome resource andcommunity that has helped me manage the 6.0 expectations and really make it anenjoyable vehicle/powertrain to own. Looking forward to getting through thisproblem and enjoying many more miles!
Old Jan 29, 2016 | 01:37 PM
Jmoen7's Avatar
Jmoen7
You do have a HPO leak, being an early motor the HPOP is almost most likely the cause. Especially if they ruled our ICP
Old Jan 29, 2016 | 03:24 PM
navistarnut's Avatar
navistarnut
I will also add, do not let them tell you they "have to take the valve covers off" to verify the leak. You will end up paying another $$$ on labor and likely it was the HPOP to begin with.
This sounds like another classical case of early build HPOP syndrome, and there seem to be a lot of them the last few weeks it's almost uncanny.
Old Jan 29, 2016 | 05:14 PM
EddieEX10's Avatar
EddieEX10
How would they check or verify that it's the HPOP?
Old Jan 30, 2016 | 05:25 AM
EddieEX10's Avatar
EddieEX10
Is there any way to verify the hpop with tests or scanners?
Old Jan 30, 2016 | 06:04 AM
WatsonR's Avatar
WatsonR
they can air test the truck to see if a leak "under the valve covers" but most likely, as mentioned, it's the HPOP. They could maybe use a mechanical gauge to check pressure, but I've really never heard of that, it would need to go as high as 3000psi.
Both codes say... low pressure.
Old Jan 30, 2016 | 09:13 AM
EddieEX10's Avatar
EddieEX10
I hear what your saying and see the point.
The dealer is not suggesting hpop because they won't know that until they get it apart? Sound right?
Has the ford replacement been improved? OK to go with a ford part if it needs replacing?
Old Jan 30, 2016 | 09:16 AM
Jmoen7's Avatar
Jmoen7
No, the Ford pump has not been upgraded. If you can afford the extra cheese id upgrade to the adrenaline stock output HPOP
http://www.dieselsite.com/2003-200460lbillethighpressureoilpumphpop.aspx
The oem pump will always be prone to fail on 03-04 trucks.
Old Jan 30, 2016 | 07:16 PM
WatsonR's Avatar
WatsonR
And they have been known to fail right out of the box or soon after, even heard several tries to get a good one.
Old Jan 31, 2016 | 07:34 AM
EddieEX10's Avatar
EddieEX10
I think Ford offers a two year warranty on both the parts and labor. If I buy an after market and it fails I'd have to pay again for the labor to replace it. Sound right?
Old Jan 31, 2016 | 07:56 AM
Jmoen7's Avatar
Jmoen7
If you have it done under their labour yes. Also when it fails you'll be down for another week, and another, and another. From what I know, the adrenaline HPOP has a very small failure rate, and I don't say that because I've heard of any failures, I say it because everything has opportunity to fail.
Old Jan 31, 2016 | 08:14 AM
EddieEX10's Avatar
EddieEX10
Is 8.5 hours a reasonable estimate to change the hpop?
Old Jan 31, 2016 | 08:51 AM
WatsonR's Avatar
WatsonR
8.5 is good, I'd of thought it was more.
Old Jan 31, 2016 | 10:41 AM
Jmoen7's Avatar
Jmoen7
I wouldn't go Ford unless you get it in writing that their warranty is 2 years part and labour. That pump is going to die again
Old Jan 31, 2016 | 11:53 AM
EddieEX10's Avatar
EddieEX10
I got 230k out of the original pump. The truck will be end of my service cycle If I get another 170k out of it.
