Sponsored by: Real Truck
Transmission Cooling
Old Aug 20, 2003 | 09:45 PM
Outpost22's Avatar
Outpost22
Originally posted by James Hewett
Mercon V , synthetic ATF is what came in my 2000 tranny and is good for 220deg. for short spells.w/no harm.
A 2000 Superduty uses straight Mercon NOT MercV. MercV will cause problems as per our resident tranny expert from Ford, Mark Kovalsky
Old Aug 20, 2003 | 10:29 PM
nafzimo's Avatar
nafzimo
Originally posted by Outpost22
A 2000 Superduty uses straight Mercon NOT MercV...
Outpost22, James has a Light Duty truck (7700), not a Superduty. Mercon V is probably correct in his case.
Matt
Old Aug 21, 2003 | 05:15 PM
Fordman4x4's Avatar
Fordman4x4
An aux cooler does sound like it would be more affective. Only problem is where to put it. Space in the radiator area is pretty limited. Where are u guys installing yours?
Nelson
Old Aug 21, 2003 | 08:12 PM
James Hewett's Avatar
James Hewett
Some aux. coolers come with plastic rods that attach to radiator cooling fins., they also can be mounted laying flat behind the bumper. or even between the headlamp and rad.on core support, just as long as air can flow thru.
Old Aug 21, 2003 | 09:15 PM
Motoxman_117's Avatar
Motoxman_117
I mounted my tru cool 40,000 gvw cooler in front of the condenser without using brackets. There are 2 plastic beams that run vertically behind your grille that you can drill through to bolt the cooler without brackets. The hard part was getting the fluid lines off the old cooler without pulling the condenser out of the way. I partially unbolted the condenser to swing the bottom of it out then you can get to the lines. The new cooler will mount on the backside of those vertical plastic beams and the grille and condenser has plenty of clearance. Hope this helps.
MotoX
Old Aug 25, 2003 | 10:32 PM
Fordman4x4's Avatar
Fordman4x4
Thanks for the info.
Nelson
Ronnie Nelson
1997 - 2003 F150
18
Feb 26, 2015 07:00 PM
vttrooper0
Dec 10, 2008 08:39 PM
Fordman4x4
Events & Happenings
Jul 21, 2005 09:17 AM
Fordman4x4
Apr 10, 2004 03:54 PM
Fordman4x4
Sep 2, 2003 02:05 PM
