95 explorer grinding
Old Jan 28, 2016 | 11:06 AM
Bigdogca1966's Avatar
Bigdogca1966
I have a 95 Explorer that I though was the brake pads needing to be replaced. I can hear grinding when slowing and turning. I am leaning towards the wheel assembly needing to be replaced.. Found them on rock auto for $50 might try it.. Anyone have any thought on the matter?
Old Jan 28, 2016 | 09:24 PM
shorod's Avatar
shorod
Wheel assembly, or hub/bearing assembly? Based on our description I suspect you are referring the the bearing being bad, which is part of the hub assembly.
Have you jacked up the wheels to get the load off of them and checked the bearings for looseness?
-Rod
Old Jan 28, 2016 | 09:49 PM
Bigdogca1966
Yep done that no tilt and no slack when grabbing the tires and checking. The only thing I can think of is that the bearings are going just not gone yet.. Going to try and replace to see if it helps..
ALedbetter1
Dec 31, 2013 06:14 PM
Crf45or1991
Oct 3, 2011 09:25 PM
Donny_D
May 27, 2011 01:54 PM
broncobasher
15
Feb 18, 2007 11:50 AM
flash041
Jan 9, 2003 07:07 PM
