Alternator installation problems…!!!!
Old Jan 27, 2016 | 07:02 PM
johnaber's Avatar
johnaber
I absolutely cannot get the long bolt on the alternator to get through to where it is threaded. it is making it about halfway through the long hole on the alternator and then gets stopped. tried lube, turning with a ratchet with pressure. it will not go any further!!!! no room for a hammer... the long bolt cannot be removed all the way out of the brackets because it hits the radiator just before pulling out, so i can't try and push the bolt through away from the van. what else should i try!!???
Old Jan 27, 2016 | 09:42 PM
fuzzybob's Avatar
fuzzybob
I might try to run a drill bit though the long hole on the alt.... or a round file or a ???. Keep at it you'll make it. Good luck.
Old Jan 28, 2016 | 08:58 AM
Turbo Dog's Avatar
Turbo Dog
Check to see of the front and back of the alternator is clocked correctly. You might need to loosen the case screws and give it a little wiggle one way or another.
Superblue400
33
Jan 31, 2026 12:13 PM
mustang81
Dec 29, 2014 08:31 AM
66F500
Dec 15, 2014 08:51 PM
whisler
18
May 3, 2012 07:04 AM
dickdollar
Nov 23, 2003 10:07 PM
