Hey there Hit Man X! Are you planning on installing the material on the inside of the doors, or under the interior panels that mount to the doors? When you purchase the material, it will come in a roll of 32" X 72" X 3/8". You can use the door panels as a template, or the doors themselves.
Hey Hit Man X! I would only cut out small holes for the window crank and the door handle. You can make slits with a razor to mount the arm rest and the push pins. I wouldn't even cut a hole for the speakers if you have them mounted on the doors. The less sound the doors have to capture the better the stereo will sound.
Well just for door handle...I use those new devices called power windows! lol. I have some foam baffles that I will also be installing on the door itself to help keep the speaker off the door.
Hey Hit Man X! Power windows? Must be nice! I'm so damn cheap! I used the foam corners from new fireplace mantles, for baffles. They were a good size for the mid-range and tweeters.
Yeah, No Hair! I know my brain isn't swelling and pushing my hair out the top of my head! I'm just glad I don't have one of them heads that are Flat in the Back! Looks like those guys can carry a pizza box on their head with a 50mph HEAD Wind! HEE HEE!
I always joke with the Stylist about not taking SO MUCH OFF this time! I'll talk with you later....
