Front Hub Assistance
Old Jan 29, 2016 | 07:51 AM
sowaxeman's Avatar
sowaxeman
Well I decided to drop the truck at a local independent diesel shop. They inspected the front end based on the gremlins I was having, and found the driver side hub was shot...needle bearing was toast, causing that sides shaft to lock in even when the locking hub was unlocked. They also found the lower ball joint was bad. They believe both sides u-joints are fine.
So rather than me throwing money at it, they are only replacing what is bad....a hub and ball joints on the DS. Waiting on the quote now.
Old Jan 29, 2016 | 08:37 AM
Rikster-7700's Avatar
Rikster-7700
If it is just the needle bearing and not the hub then you can just replace it, NAPA sells a replacement, if I wasn't on my phone I would try and find the right part number, a quick search should point you in the right direction. It may even be listed in guzzles how to?
Olsenc25
1997 - 2003 F150
Feb 27, 2019 09:04 PM
TKegs763
Sep 25, 2013 07:45 PM
Pitcrw6
May 6, 2012 09:00 PM
Monark
Dec 14, 2009 06:06 PM
dew the thunder
Apr 20, 2009 06:47 PM
