Source for rebuilt steering column
Old Aug 9, 2003 | 12:11 PM
jlasater's Avatar
jlasater
I'm in the market for a fully rebuilt steering column for my 1971 Ford F-250 with AT. Do any of you guys have a good source for one?
Old Aug 10, 2003 | 04:15 AM
willowbilly3's Avatar
willowbilly3
What's wrong with yours? I know of no sources for a complete one but may be able to help you out. E-mail me at jb.hoffman@verizon.net
Old Aug 11, 2003 | 01:38 AM
mirabida's Avatar
mirabida
I need to do something with my column too. I think the bearings are gone and my rag joint is separating. Where would I get new bearings?
Old Aug 11, 2003 | 02:11 AM
willowbilly3
Try the store here first. I saw the bearings just a few days ago and I think it was in my Mac's catalog. I'm not sure on the rag joint. The local parts store may have them.
If your bearings are shot you should check your cab mounts. Mine were bad on my 72 and I ended up replacing the cab mounts, floor pans and most of the kick panels just to get to decent metal and there was no rust through showing on the truck. I also went on in and pulled the front clip and engine to repair the seam in the firewall. The engine was a little tired so I rebuilt it while it was out and also decided to repaint the truck and replace the bent grill shell and dull bumper. WOW! talk about picking a scab. I ended up spending over $4000 on that truck and it just started out with replacing the steering column bearings.
Old Sep 4, 2003 | 02:15 PM
67f100hd's Avatar
67f100hd
I found an outfit that sells 65-79 f100 steering column for either automatic(column shift only) or floor shift (manual or auto). They supposedly come primed for paint, brushed or polished. Also they TILT!. Has signals and flashers. Try www.hotrodsuperstore.com If that doesn't work, search for 1967 ford steering columns and you'll find there link around number 6 or so. By the way, according to the web site, this column sets you back about $600
