Radiator mounting question
Old Jan 23, 2016 | 09:17 PM
tigerfan79's Avatar
tigerfan79
When mounting the radiator to the support, are lock washers needed? I purchased a new aluminum radiator along with new bolts and cage nuts but was unsure if everyone is using lock washers or just some loktite.
Thanks.
Old Jan 23, 2016 | 09:42 PM
drptop70ss's Avatar
drptop70ss
I use flats, locks, and anti-seize on the bolt threads. This is a champion radiator.
Old Jan 26, 2016 | 07:34 AM
DougofMontana's Avatar
DougofMontana
Which fan/controller are you using Dave? I like that upper bracket, did you make it?
Old Jan 26, 2016 | 01:01 PM
drptop70ss's Avatar
drptop70ss
Hi Doug,
In this case the fan is PCM controlled, I just setup the on and off temperature set points.
For non PCM control I use Derale adjustable fan controllers which have worked fine. I would never buy a non adjustable controller, having the adjustment lets you compensate for temperature sending unit location and tolerances.
I made the fan mounts out of scrap round rod, pics are in the truck #2 build.
Old Jan 26, 2016 | 03:00 PM
DougofMontana
Thanks for the info, Dave!
Old Jan 26, 2016 | 08:20 PM
tigerfan79's Avatar
tigerfan79
Thank you.
1948 F1dude
Aug 27, 2014 06:44 PM
Mannella9
Mar 20, 2012 01:48 PM
Jupes
Apr 30, 2011 09:03 PM
svooom
70
Jun 15, 2007 10:48 PM
jmooremtb
Apr 12, 2004 01:39 PM
