Ignition switch broken
Old Aug 9, 2003 | 05:56 AM
taketheredpill's Avatar
taketheredpill
I just picked up a 95' F150 yesterday. Whenever I open the drivers side door it makes a buzzing sound (key in the ignition or not ). Looking into the problem, I found out that I don't need a key to start the truck - the iginition switch turns freely. Do I need to buy a new iginition switch - any ideas how much $? Also, it this hard to change - do I need to remove the steering colum? Thanks for any help!
Old Aug 9, 2003 | 08:57 AM
paulfix's Avatar
paulfix
Mine did the same.
The buzzer is located near the drivers knee, I reached under and pulled it out. no more buzzing (at least for leaving the key in - or not)
Old Aug 9, 2003 | 10:10 AM
Airbrush's Avatar
Airbrush
If you need a new ignition lock cylinder, the one from Ferd comes with the "kit" to make it match your key. It was about $25 last time I got one. You need a drill bit or small fillipe screwdriver to get the old one out of the column. Your manual will cover this but replacement is seconds once it's keyed.
Old Aug 9, 2003 | 10:29 AM
Trail Rider II's Avatar
Trail Rider II
Auto Zone $12.50 with keys.
