engine brake?
Old Aug 8, 2003 | 09:31 PM
ExcellentRed's Avatar
ExcellentRed
engine brake?
Hey guys,
I experimented today with downshifing on my automatic to stop coming to a redlight. Often I will pull off the OD to help slow down a bit, but i found that if when i get to about 40 i pull the level to 2nd, then at about 25 i pull it to 1st, i can stop by barely tapping the brakes. I doubt this is something I would do all the time, because its more involved than braking, but do you all think its okay to do that with the truck? I mean, it's not hurting the tranny, is it?
Old Aug 8, 2003 | 09:36 PM
rebel_ford4x4's Avatar
rebel_ford4x4
engine brake?
thats something ive messed with a few times too, except i wait til about 5 or 10mph to shift down to 1. any faster than that feels too fast to me for 1st gear. i dont have a tach so i cant tell if its revving too high or not. ive had the same question as you though so sorry i cant help ya. ill be watching the post to find out though...
Old Aug 8, 2003 | 10:20 PM
ExcellentRed
engine brake?
Yeah the shift into 1st gives a heavy lurch, but the tach usually doesnt go over 2200 when you let it go to about 25 mph or less.
Old Aug 9, 2003 | 12:39 AM
Torque1st's Avatar
Torque1st
Posting Legend
engine brake?
It does put extra wear on the clutches and bands. I think brake pads cost less to replace...
Old Aug 9, 2003 | 10:45 AM
ExcellentRed
engine brake?
okay, that's what i wanted to know. I suppose I should only use that method if I need to supplement the brakes when stopping hard.
Old Aug 9, 2003 | 05:00 PM
90f150moneypit's Avatar
90f150moneypit
engine brake?
The only time I downshift manually is if I'm on a high mountain coming down a gravel logging road. But I only use 1st at about 5mph. That way I don't pick up speed going down. The downshift from higher speeds, like normel driving, will kill the trans.
7.3F450
Jun 26, 2013 12:17 PM
BigBlockF350
56
Apr 2, 2013 05:55 PM
gabeyd
Jul 4, 2012 07:00 AM
franklindc
1983 - 2012 Ranger & B-Series
Jun 3, 2006 07:06 PM
RCE
All Things Towing
May 17, 2006 11:41 AM
