Brake Backing Plate
Old Jan 12, 2016 | 07:39 PM
jmhj's Avatar
jmhj
Brake Backing Plate
Having a really hard time finding a left rear brake baking plate for my 77 F100. Anyone know if I can use one from a different year or maybe even from a Bronco. Just looking for options. Thanks.
Old Jan 12, 2016 | 09:52 PM
BLK79's Avatar
BLK79
Should be a 9" axle. I THINK any 9" from F150 73-78 SHOULD have same backing plate, also 78 Bronco. In 79 (sometime) the housing ends changed to smaller bolts, which match backing plate. U did say F100, I'm assuming should be same as F150
Old Jan 12, 2016 | 10:33 PM
ultraranger's Avatar
ultraranger
'68-'86 9-inch truck rear end backing plates for 11" x 2-1/4" drums with a 5 x 5.5" lug pattern will be a direct fit. The backing plate will need to have (4) 1/2" backing plate bolt holes on a 3-1/2" horizontal pattern by 2-3/8" vertical bolt pattern. (Old style large axle bearing pattern).
There was also an old style large axle bearing pattern but it had 3/8" diameter backing plate bolts. This will be obvious to spot that the backing plate bolts are smaller than 1/2".
There was also a newer 'Torino' style large axle bearing flange with 3/8" backing plate bolts but, it was on a wider 3.562" horizontal bolt pattern by a narrower 2.00" vertical pattern.
Old Jan 18, 2016 | 07:13 PM
jmhj's Avatar
jmhj
Thanks for the replies. I believe it is a dana 44.
Jmiller68
Mar 12, 2017 07:12 AM
jecsd1
Jun 16, 2008 03:00 PM
jmurder
Mar 6, 2007 09:46 PM
jwcnj45
13
Jul 23, 2003 06:18 PM
