Sponsored by: Auxito
Right Side Door Replacement 1997
Old Aug 8, 2003 | 03:51 PM
doxie52's Avatar
doxie52
I have a replacement side mirror for the right side. I have no clue on how to got the inside door panel off. I started but got frustrated. Can you help! Thanks
Old Aug 8, 2003 | 06:38 PM
HomerWinzlow's Avatar
HomerWinzlow
97 F150? Well depends on the panel style, but most you just pop off the upper trim pieces on either side, and pop out the retainers. If you have power windows pull off the switch plate and disconnect the power leads and set the switches and plate aside. Pull the escutcheon plate around the inner latch handle which just snaps into place. There will be one screw under that latch handle escutcheon plate. Remove that screw. Not all door panels have two upper trim pieces so if yours only has one then remove it and that retainer under it. If you have all the retainers out then simply grasp the bottom of the panel and give it a tug upward. The door panel has a bunch of hooks on the back side and you are simply unhooking them from the panel. The panel should then lift off and you just disconnect the courtesy lamp from the socket if equipped. Reverse order for installation. Some older model panels didnt have the escutcheon plate around the inner latch handle and just have a small trim piece you remove, and then you remove the handle itself with an 8 mm socket tool. Also some have an additional screw just inside the area where you pulled off the switch plate. If you missed a screw you will know as that panel will not budge. Some models may also have a screw hidden behind the lens on the courtesy light. If the lens is removable you will be able to tell by the indention in it made for a small screw driver to pop it out.
Now all this is off the top of my head from memory but that is about all you need to know.
Old Aug 8, 2003 | 08:09 PM
Racerguy's Avatar
Racerguy
Homer do you mind if I make your reply here part of the FAQ that I posted on the front page of the forum?
Old Aug 8, 2003 | 08:10 PM
HomerWinzlow
Sure Racerguy, Im happy to help any way I can.
Old Aug 9, 2003 | 09:41 AM
BlueOvalFitter's Avatar
BlueOvalFitter
Brown noser!
Old Aug 9, 2003 | 07:15 PM
Racerguy's Avatar
Racerguy
Ok BlueOvalFitter if you play nice maybe I'll let you do a question for the FAQ too
lol
