Clear coat
Old Jan 11, 2016 | 06:26 PM
460 1997's Avatar
460 1997
Clear coat
Hey you body and paint guys..and girls...Is there any way to sand down and remove the clear coat on a 1997 f-350 ? My clear coat is peeling and bubbling off my truck...on the blue only and on one side only. I have heard people saying before that they have removed the clear coat and saved the paint... Is this possible? Thanks
Old Jan 13, 2016 | 08:59 PM
Beechkid's Avatar
Beechkid
Well, yes you can sand & remove the CC but, the base coat paint is not going to last very long because it is just a coverage coat...very thin by comparison.
Old Jan 18, 2016 | 05:01 AM
karlduke's Avatar
karlduke
Another solution is to sand it all bare and let a body shop do the painting.
Old Feb 23, 2016 | 11:18 AM
CharlieLed's Avatar
CharlieLed
Simple answer is NO. Clear is very hard and requires fairly aggressive sanding to remove, basecoat is non-catalyzed and very thin which means it will disappear without much work at all. There is no easy fix, the clearcoat should be completely removed and whatever refinishing is needed after that should be done...it will at least require a sealer, basecoat, and clearcoat.
brcrk
Jun 12, 2012 10:03 AM
hatchet
Paint & Bodywork
May 28, 2008 09:28 PM
Ohiostomper
Appearance & Dress-Up
13
Apr 23, 2007 07:53 AM
95se5m
Paint & Bodywork
Mar 7, 2004 10:51 PM
starweb
Paint & Bodywork
Jun 23, 2003 11:37 AM
