Newbie to ford...
Old Aug 8, 2003 | 02:03 PM
newbietoford's Avatar
newbietoford
Newbie to ford...
I am doing a big project on a 390 and I would like input from everyone on what steps they would take to get the most out of the engine. The heads are c8ae-h. Also, anyone know where i could get a 4 speed manual???
Old Aug 8, 2003 | 02:21 PM
V8sRus's Avatar
V8sRus
Newbie to ford...
We will also be doing a 390 project by the looks of it, so all replies will be twice as appreciated,
Old Aug 9, 2003 | 06:10 AM
pat67shorty's Avatar
pat67shorty
Newbie to ford...
1rst, add headders. They are worth more power on an F.E. than other engines due to the F.E.'s restrictive manifolds. 2nd, 4v intake and carb. You'd be amazed how much power you instantly pick up. 3rd Cam. same as other two. The stock grind is way tame and is out of breath just after 4,000 rpm.
Old Aug 10, 2003 | 01:52 AM
newbietoford
Newbie to ford...
Thanks for the advice. I have read that the stock heads can hold the cobra jet valves, is that true, and would that help a lot or just be a waste???
Old Aug 10, 2003 | 03:00 AM
pat67shorty
Newbie to ford...
I suppose you could put CJ valves in a std head, but the std head's ports are smaller than a CJ's.
Old Aug 10, 2003 | 07:48 AM
Ratsmoker's Avatar
Ratsmoker
Newbie to ford...
Adding CJ valves to a stock head is a great upgrade. It doesn't take much port work at all to get a regular truck head to flow like the CJ heads.
