HIGH IDLE
It was a $75 part.
My 2000 had a lot of issues with idle and every 6 months or so I would have to replace IAC and it would work for a while and then start high idling again. Through a lot of trouble shooting it was actually me disconnecting and reconnecting the connectors that temporarily fixed issue.
Me being cheap, I wasn't about to spend $75 on a crappy looking fix, so I took the IAC and TPS connectors apart and hosed off each with Electronic parts cleaner and while the connector was wet, I connected and disconnected several times to help clean out the corrosion. Once connector was dry, I used dielectric grease on the connectors to prevent further corrosion. My truck has been high idle free for over 6 years now
I replaced the IAC but that was NOT what I disconnected with no change. I was disconnecting the TPS
with no change. When I disconnect the IAC the truck stallsI cleaned both connectors and put diametric grease on them. Started the truck up and it was ar 2100rpm
As I was hooking the scanner up the idea slowly dropped down to normal
LTFT says the computer is having to Add fuel over time to compensate for what it's determined over time to be a lean trending air/fuel mixture. Could be lazy/slow switching O2 sensors, dirty fuel injectors, clogged air filter or air intake, clogged exhaust, misbehaving sticking open, or worn not seating closed PCV valve, or loose leaky hose or fitting to it, intake manifold vacuum leak, brake booster vacuum leak, emissions system vacuum leak, in cabin heater/ac control system vacuum leak, the list goes on & on.
SO, measure the STFT, LTFT & upstream O2 sensors switching range & speed on Both cyl banks, MAF sensor info & lets see if you can narrow your suspect list down to a particular cyl bank, or if it appears to be an over all problem that would suggest looking upstream at a dirty MAF sensor, clogged air filter, or air intake, or dirty fuel injectors if both cyl banks seem to be trending lean over time.
Exhaust is good, I actually just punched out the "collector" cat
O2 sensors are maybe 2 years old
Air filter is good
I run seafoam periodically in the fuel for cleaning purposes
I an check the MAf but being intermittent, I cant see that being the problem
I am leaning more towards faulty wiring
Make sure the Basics are right. Under Load battery & alternator voltage are in spec. Battery to engine & body grounds are clean bright & tight. Perform a wiring harness wiggle/thump test at the IAC & computer harness & electrical connectors, to see if you can induce it to act out. Make sure you have B+ to the fuel injectors at KOEO, so they are squirting right, if the computer grounds are clean, bright & tight & the injectors are clean.
A 20 oz dose of Techron Concentrate Plus in the tank at the pump before filling with Chevron, Texaco, Caltex, or now Shell, (all of which have some PEA in their ad pack), will raise the treat rate 10X above pump gas alone, so can tidy up dirty fuel injectors often in one treatment. It can also decarbon the intake valves, piston crown & combustion chamber.
The IAC is a common problem part in idle speed woes. Cleaning the IAC often doesn't last, it didn't for me on the 99 Ranger, but was a good trouble shooting step before replacing mine with a BWD. Motorcraft, or BWD are recommended replacements if it comes to that.
More thoughts for consideration, let us know how it goes.
Grounds are good.
I have 13v at and idle
If you don't have removable cell caps, perform a open circuit voltage test with your multimeter after the battery has rested over night & before you start the engine.
If you are in doubt on how things are testing out, run this puppy by your favorite autoparts store for their in vehicle electrical system check up. It can trouble shoot the battery, alternator, battery cables & their connections while in the vehicle & properly done can give us a good idea of our electrical system health.
Since in the past you've gotten positive results replacing the computer, did you include its firewall electrical connector in your pin/socket/wiring inspection for damaged wiring, poor wire crimp, pushed back pin/socket, bent pin/mashed socket, pin/socket corrosion & a wiggle test on that connector while the engine is running, to see if you can induce the problem????
Are the computer grounds clean bright & tight?? Did the replaced computers show any signs of having had water on them???
