horn issues
Old Jan 8, 2016 | 04:00 PM
pinn600's Avatar
pinn600
horn issues
Can someone tell me if a 68 Ford F600 has a horn relay,and if so,where is it.Can"t get power to horn.Everything in steering wheel seems intact.Thx
Old Jan 9, 2016 | 09:21 AM
D & D's Avatar
D & D
If it has the same horn mounted to the inner side of the radiator support, it should have the relay on the passenger side inner fender.
Good grounds do wonders for electrical issues.
Old Jan 9, 2016 | 09:53 AM
Alex from GA's Avatar
Alex from GA
Have you tested the horn with 12v going directly to it? If you can, follow the smaller wire from the battery side of the starting relay and the next thing you run into is the horn relay.
Old Jan 12, 2016 | 01:14 PM
JEFFFAFA's Avatar
JEFFFAFA
Actually I thought it would have the same horn relay as a pickup also. But it doesn't. In my 65/72 truck slide it says:
67....F-T500/1000......not used on units built from ser #B12,001.
It prolly has a stud type of relay somewhere. There are some of these listed for your F600 but Ford does not say what circuit they are for.
pinn600
Large Truck
Jan 8, 2016 03:01 PM
bill2298
Jan 13, 2015 07:51 PM
bloodspoint
13
Sep 11, 2010 12:55 PM
Dirt1dobber
Sep 23, 2006 03:12 PM
GSchretter
Oct 23, 2003 10:19 AM
