question
Old Jan 8, 2016 | 12:12 PM
scrooge's Avatar
scrooge
question
I am a new owner of a 2012 used f-150 5.0,I had a 07 f-150 5.4..07 had OD (overdrive) turn off button ,2012 has a tow haul button,,is that basically the same thing as OD switch?? Thanks for any replies...
Old Jan 8, 2016 | 01:52 PM
Olytlr's Avatar
Olytlr
The tow/haul mode will change the shift strategy. I have never noticed it lock out 6th gear.
Old Jan 8, 2016 | 01:54 PM
Robbgt's Avatar
Robbgt
Congrats on the new truck. The tow/haul button is different than the O/D off. It changes the programming in the transmission to hold a gear longer, changes the TC lockup strategy, and downshifts when slowing. The transmission does give the option to "lock out" gears, similar to the OD off on your 5.4. Simply press the minus (-) button on the shift stalk and you will see that gear removed from the display. You can continue down as low as you like. I haven't found a need to lock out gears with the addition of tow/haul mode, it does a really good job
Old Jan 8, 2016 | 02:16 PM
scrooge's Avatar
scrooge
Thank you very much...
rlt7272
Mar 6, 2013 05:19 PM
96speed
Oct 10, 2011 06:01 AM
barthel
Modular V10 (6.8l)
Sep 19, 2011 02:51 PM
celliott
Jul 2, 2008 09:44 AM
MarkMoore
Oct 4, 2006 05:28 PM
