Sponsored by: Real Truck
Instrument cluster
Old Jan 21, 2016 | 06:55 AM
projectSHO89's Avatar
projectSHO89
Seriously, go back and follow the specific directions given. This ain't rocket science, after all.
Reply ONLY after you've done your part of the work or if you have specific questions about how to do the work and need assistance.
Old Jan 22, 2016 | 10:07 PM
CircuitBoardMedics's Avatar
CircuitBoardMedics
Originally Posted by Poncho450
If you can go without the truck for a bit you can contact Specmo Enterprises (they fixed a cluster on my 2003 Cadillac) or try Speedometer Repair | Speedometer Not Working | MyAirbags
The second outfit had my Crown Vic cluster. When they determined that they couldn't fix it due to some type of bad internal issue, they refunded all the money minus shipping charges.
We rebuild a lot of those "non-repairable" clusters. Give us a shot next time.
Old Jan 23, 2016 | 03:17 AM
Firefighter437's Avatar
Firefighter437
I haven't got it fixed yet let me know how to get in touch with u and I'll c what I can do
Old Jan 23, 2016 | 07:31 AM
projectSHO89
Exactly how hard is it for you to click on their website link in their signature? Or google their company name?
Old Jan 23, 2016 | 07:48 AM
Poncho450's Avatar
Poncho450
Had I known about you, I most assuredly would have. But that car is long gone now. Hopefully I don't have any issues with the 4 vehicles that I currently own.
I am however, bookmarking you now just in case!
Old Jan 23, 2016 | 04:15 PM
CircuitBoardMedics
Call us anytime at 800-547-2049
Old Jan 23, 2016 | 09:32 PM
Shepherd2's Avatar
Shepherd2
Check power and ground at the connectors.
Connector 1, Pin 12 R/Y wire should have power with key on
Connector 2, Pin 5 PK/O is ground
Pin 11 R/Y power with key on
Connector 3, Pin 12 BLK is ground
Old May 22, 2016 | 07:43 PM
Hotairjunkie's Avatar
Hotairjunkie
Can anyone tell me if the fuse numbers and pin outs referenced in this thread would be the same on a 2001 F250SD? I am just starting into troubleshooting an inoperative cluster on this truck.
Thanks.
Old May 22, 2016 | 08:15 PM
Hotairjunkie
Follow up; F19 blown. Replaced fuse and cluster and O/D on/off are working now (O/D on/off was inop also). If it blows F19 again, I'd suspect it is likely the chafed wire in the shift tube. Can someone provide some guidance as to where exactly I need to look to find this wire and re-insulate it?
Also, as a side note, I had originally checked F16, which is notated in my manual as instrument cluster and Hi-beams and have no power on either side of the fuse. Any ideas there?
Thanks again all!
Old May 22, 2016 | 09:48 PM
Sam I Am's Avatar
Sam I Am
Thanks again all!
Turn on the high beams and test again.
Old May 22, 2016 | 10:13 PM
projectSHO89
Remove the shrouds on the column. Look for the end of the shift lever that is normally covered. Look for the wires coming out of it.
BINGO!
timmyboy76
Dec 22, 2017 01:10 PM
MAULMAUL
Oct 7, 2010 10:26 PM
