Jacobs
Old Feb 10, 2002 | 01:21 PM
Mike Lewis's Avatar
Mike Lewis
Jacobs
I installed a Jacobs RV Ultrateam kit into my '91 Ford F-150 yesterday, and notice that the truck has less low-end than it did before the install.
Has anyone else noticed this with the Jacobs kits? Mid range SEEMS better, but I can no longer accelerate, for instance, from 45-50 without the truck downshifting. Truck also loses speed and downshifts on a hill that I can otherwise take (lose speed, no downshift) with the kit disconnected (pulled fuse and reconnect stock coil-distributor wire.)
What's going on?!?!? Or is some loss of low-end normal?
I regapped the plugs to 0.064" as recommended by Jacobs (standard gap is 0.044").
Thanks,
-Mike
Old Feb 10, 2002 | 04:18 PM
GammaDriver's Avatar
GammaDriver
Jacobs
http://www.se-r.net/engine/ignition.html
there are some criticisms on that page, plus I was searching for a report on a mustang (i think) project car that they found some losses of torque (i think that's what it was - at some RPM level) on. I couldn't find it (but I did view the page within the last two months, so I bet it's still out there). But I did find a number of criticisms over Jacobs ignition claims and performance. It seems to be an over-rated CDI box... equal to other mid-level CDI boxes, but lacking the extra kick out of MSD's patented multiple sparks. But then a lot of people seem satisfied with Jacobs, too.
(here's a less-than informitive criticism of the ignition:
http://www.goingfaster.com/spo/gallery.html )
After all that searching and reading I just did, I'm a little more relieved I bought the MSD a month ago. Sorry if that sounds biased, but this was my first CDI purchase, so I'm a bit glad I came out ahead on the deal. I wanted the multiple sparks under 3500 RPM anyway because the I-6 isn't a high revving engine like the V-8's.
One post indicated a guy did bitch at Jacobs, with dyno sheets to prove that there was no improvement, but to no avail.
Have you checked your timing before and after installation?
Old Feb 10, 2002 | 06:55 PM
rondog's Avatar
rondog
Jacobs
Just a quick note. I put a Jacobs system in my '94 F-350 crew/dually (460/auto)and really didn't notice much difference. However, at about 1500 miles out of warranty, the Jacobs coil unit went bad. I replaced the spent unit with my stock unit (which I held on to) and disconnected the Jacobs computer and the truck ran fine till I sold the truck. Jacobs was no help, indicating that since the coil was out of warranty, there was nothing they could do... except sell me another one.
Old Feb 12, 2002 | 05:24 PM
mjb1962's Avatar
mjb1962
Jacobs
I tried Jacobs a few years ago. It was their top of the line "Ultra Team" and the system would not work as designed with the 302 V8 in my 89 F150. It caused a low to mid rpm misfire under load. Jacobs was no help in that all they could do was take the system back for a 10% restocking fee. What a RIPOFF! Buy an MSD system.
Mark
Old Feb 12, 2002 | 09:42 PM
F150xlt's Avatar
F150xlt
Jacobs
