1978 - 1996 Big Bronco
Mini Spool?
Old Aug 13, 2003 | 12:28 AM
Matts72's Avatar
Matts72
Mini Spool?
Originally posted by greystreak92
mattsbox,
Well, ya know, I have yet to try the idea of broadsliding through turns on dry pavement but maybe you are on to something!
Its freakin awesome
Old Aug 13, 2003 | 12:42 PM
jopey's Avatar
jopey
Mini Spool?
tsk, tsk.
Ox went out of business.
Detroit elec-trac I heard was for Dana 44/dana 60 only right now. Probably never for a nine.
ARB = $$$$
I have ran a detroit in the back of my 78 in a nine with 35's and 38's. went to a 14 bolt and welded it. I perfer the detroit. but I am not running out to buy one just yet. It does stress the shafts more and tire wear will go up if driven daily on the street. but I would not rule one out just because of these reasons. you need to rationalize why you actually need one. then go from there. Put all the pros and cons on paper then decide.
Old Aug 13, 2003 | 12:44 PM
jopey's Avatar
jopey
Mini Spool?
DW has a very valid point about using a spool on the street. The strain on the driveline around corners will either eat gears, axles, tires, or all three.
I would like to know how it will eat gears???
Old Aug 13, 2003 | 01:00 PM
jaws92174's Avatar
jaws92174
Mini Spool?
I have a 1990 with the 8.8 in it and I installed an Auburn Locker about 3 or 4 years ago and have not had any problem yet. Its my daily driver, and the locker is an automatic one. I love it and it helps a whole bunch off-road too.
Old Aug 13, 2003 | 10:22 PM
mrwizard's Avatar
mrwizard
Mini Spool?
I had a home made "spool" in a '66 Mustang a long time ago. Actually, I just blew up the spider gears and they embedded themselves inside the carrier. Driving that way on the street, even for a short distance, is bad. It made the whole rear end of the 'stang hop going around even a slight turn. My advice, spools and street driving don't mix.
