97 F150, 4.6, blend door , actuator good, (gained access, checked actuator, door) new t-stat. Very little heat. Temp control valve(if installed)? Temp selector switch? Any Ideas are greatly appreciated.
With the engine warmed up, what is the condition of both heater hoses? You have to determine if hot coolant is actually flowing through the heater core.
Had blend door actuator off, r (replaced) was able to cycle door manually. with eng. warmed up, and actuator removed, cycled door again, still no heat. one heater hose is warmer than the other.
Forget messing with the ****, it isn't the problem. You already proved that when you observed the operation of the blend door earlier.
The actual problem is that you do not have hot coolant properly circulating through the core. With the engine fully warmed up, both hoses should be too hot to touch for more than a very very short time as the circulating coolant should be 190F+.
Typical causes are low coolant, air bubble in the heater core loop, kinked or faulty hose, clogged heater core, or a worn out pump.
Ford didn't install a shutoff-valve from the factory in the half ton pickups, but that doesn't mean one wasn't added later. You will need to physically inspect the lines.
That's not true at all. The Hose feeding the cooler has a restrictor in it, limiting flow to the Heater core. The heater Core is a heat exchanger, it's job it to take heat from the coolant. Therefor the hose unto the core will be hotter (usually noticeable) than than discharge line of the core.
If one is hot and one is stone cold, that's a different story... and the heater core could be clogged.
EDIT: To the OP:
Do you mean that you physically cycled the door with the truck warmed up, and the heat vents on High? Or that you just just moved it, then reassembled it. If the former, then projectSHO is onto something.
