Just curious what kind of mpg everyone's getting. I've got a 97 ext cab 4x4 auto 7.3 and I'm getting anywhere from 18-20 mpg. This is a bone stock truck.
That sounds like 4.10. Look on the driver's door jamb for a sticker; what's the AXLE code? If it's C9 or 39, it's 3.55. If C5 or 35, it's 4.10. That's pretty good economy for 4.10s.
Before the instrument cluster issues became severe, my 4.10:1 open differential with the E4OD averages 18.5 MPG unloaded. I get about 12 - 14 MPG loaded/towing the travel trailer. I think those numbers might be a little higher, but it's difficult to calculate when the odometer blinks off and back on. When it comes back on, the mileage accrued is less than what it was before it blinked out.
On a run to Oklahoma City last night to watch my grandson wrestle in regionals, I got 13mpg in stock mode, running at a constant 65mph unloaded. I was a little disappointed but oh well, it's not a compact.
My mileage may be more like 15 plus vs 13. I didn't take my larger than stock 235/85/16 tires into consideration before. The old owner said the speedo is around 3 mph off.
I average 17-18 now with a manual and 4.10s...best I ever had was 21.8 in the mountains. Worst was 7.9. 25 mpg on 4.10s... must have been running a gear vendor behind that zf lol
There are only 22 f-350's with 7.3's in the list below, but it is a pretty good tool.
I have a '96 automatic F250 with a 3.55 differential and factory-sized 23585R16 tires. Through the past 20 years of ownership, I found I can depend on the following:
