Sponsored by: Real Truck
Flat bed build
Old Jan 1, 2016 | 09:46 PM
Sky505's Avatar
Sky505
Flat bed build
Flat bed by Sky505 | Ford-Trucks.com
Old Jan 1, 2016 | 10:20 PM
davester250's Avatar
davester250
are you using wood planks for the bed? If so, I would suggest clamping the planks down so you can remove them instead of screwing them down like you see most beds. It makes working on the rear of the truck SO much easier, to be able to work from the top instead of only from the bottom.
Old Jan 1, 2016 | 10:32 PM
Sky505's Avatar
Sky505
Thanks for the suggestion bud. Unfortunately for me most of the work I need to do is on that crap 5.4 under the hood. The headers sound like a helicopter right now, and I just ran into an issue with the oil cooler. I posted it on here and is the reason I just joined this site.
Old Jan 2, 2016 | 02:52 AM
davester250
it's a "down the road" kind of thing. as the truck ages, stuff goes bad. Using self-tapping metal screws [seems to be the most common way to attach them] rust and you either do the work from the bottom or you have to cut the boards out. clamp 'em down and then it's only a couple minutes to do things like changing the fuel pump vs draining/dropping the tank, looking at how badly the brake lines are rusted, changing shocks, wiring problems [as the harness is normally inside the frame rails].
Old Jan 2, 2016 | 09:24 AM
BigMacWelds's Avatar
BigMacWelds
What kind of clamps would you use?
Interesting idea. What kind of clamps did you have in mind? Do you have a picture of how they'd work? Thanks and Happy New Year!
Old Jan 2, 2016 | 04:38 PM
davester250
Bret4207
Dec 28, 2015 01:03 PM
EasternJU87
Nov 20, 2015 08:16 PM
STLford
Jul 10, 2010 12:42 AM
frederic
28
May 9, 2005 09:28 PM
StockMan
Oct 31, 2001 06:21 PM
