2002 Escape 3.0L 4wd thumping noise/shaking
My brother has an 02 ford escape that he bought cheap because it needed a transmission. He just replaced the trasmission in it as well as tie rod ends, front axles, axle bushings and seals. The front pads and rotors are new and the tires were just rotated. Now when you are going 15mph and up and are on the accelerator there is a severe shaking as you accelerate and a loud thumping noise. If you let off the accelerator it goes away. If you get it going fast enough it will shake so bad the mirrors will shake. He is a ford mechanic but said he is having a hard time pin pointing what it could be . He took me for a ride and I have no idea what it might be. He said he has had other mechanics look at it but they can't figure it out. Just figured maybe someone on here has an idea that we aren't thinking of. Thanks in advance.
Wheel bearing maybe? does it completely go away or just get much quieter? Is the thump like once for every wheel revolution or does the timing seem to be slightly different?
Any chance this could be engine related like a bad plug or COP?
I have an '02/3.0/4WD as well.
The shaking feels alot like you are down a few cylinders I will ask him if he checked that. Thank you for the response anything else that comes to mind from anyone please let me know.
saigonoakuma
1997-2006 Expedition & Navigator
06-20-2016 05:38 PM
og5
02-02-2005 12:15 PM
