New Year EXCURSION Resolutions
Old Jan 1, 2016 | 09:30 PM
agsmv1's Avatar
agsmv1
Originally Posted by Krazee Matt
You still hung over from last night? V10's had the 4R100, 6.0 had the 5R110. There is literally NO way of making the two trans interchangeable due to shift logic and programming.
Maybe we can indeed
38R is still too small for my Stage 3's, so I need MOAR TURBO
Then I guess I have dibs...lol
Old Jan 1, 2016 | 09:37 PM
USCG_PA's Avatar
USCG_PA
Lets see (product links provided):
Will do:
New Wheels (5)
New Tires (5)
New Brakes and braided brake lines
Fix the lie-o-meter
Keep it clean and running strong!
Might do:
RAS
Roof Rack/Basket
Fender Flares
Custom tunes for the 6.0
Old Jan 1, 2016 | 09:57 PM
High Cetane's Avatar
High Cetane
Well, the '16 plan was 10k miles with the boat in tow...but now with retirement over...going to have to settle for 5k.
New wheels would be nice too...Centerlines are looking a bit dated.
Old Jan 1, 2016 | 11:46 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Plan for my Ex in 2016.
Drive it more!!! 4k miles last year was not enough!
Install a boss snow plow mount and wiring
New rear hatch shocks
New wiper nozzle on the drivers side
Rigid lighting
Repaint hood
All I can think of right now.
Old Jan 2, 2016 | 01:17 AM
Drunken_Unicorn's Avatar
Drunken_Unicorn
I'm not planning on making the 6.0 trans work with it. The newer 3V V10 use the 5R110W and play nicely together.
Yes, I am a little hungover... Like always
Old Jan 2, 2016 | 01:22 AM
Drunken_Unicorn
Originally Posted by nmclella
I think he means to drop a 3V V10 and the 5r110 which were paired together post 2005 I believe. Don't know how he would reprogram the Excursion computer for it though
I'm not 100% sure it would work, but the harness and ECU from the doner would be the only way I would do it. I would essentially have the brain box of a 05+ superduty or motor home.
Making all of the dash stuff work would be the real trick. Lol
Old Jan 2, 2016 | 01:31 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
What I'm hearing you need a donor 05-07 SD. new axles, engine, transmission, dash, computer..ect
Old Jan 2, 2016 | 01:45 AM
Drunken_Unicorn
Pretty much. Not really a cost effective plan/project and definitely not realistic for my Ex and myself.
Might be fun for a future project though.
I shouldn't be putting my wild dreams in a resolution thread
Old Jan 2, 2016 | 08:57 AM
jhcorley's Avatar
jhcorley
Get the shift on the fly 4X4 to work 100%.
Old Jan 2, 2016 | 01:44 PM
05MilMachine's Avatar
05MilMachine
Fixed my first one today! The rear hatch lock. Just needed cleaned and lubricated. Works like new!
Old Jan 2, 2016 | 05:14 PM
TexPiggyPounder's Avatar
TexPiggyPounder
A 05 coilover axle swap & 2015 interior conversion. Last two projects left to have my Ex fully restored/converted!
Here is my current list of addons. On my 04 6.0 Excursion
Head Studs, New OEM injectors, New OEM Transmission, Mishimoto Radiator, Sinister EGR Delete with Up-pipe, New Up-pipes, New OEM oil cooler, New OEM Water Pump, New OEM Alternator, New OEM High pressure oil pump, Sinister coolant filter kit, Sinister oil bypass filter kit, New 03 OEM Turbocharger and pedestal mount, New Blue top Optima Batteries, SCT livewire with TSD custom tunes, Autometer Cobalt Trans, Fuel pressure, Pyro and Boost gauge, Autometer gauge dimmer control, Tekonsha trailer brake controller, 4'' Stainless Magna Flow Exhaust System with 6'' SS tip, S&B cold air intake system, CFM plus intake manifold, New OEM Engine Harness, New OEM AC Compressor, OEM AC Lines to rear cab, Upper and Lower radiator hoses, New OEM fuel pump, New OEM Fuel Sending unit and cleaned fuel tank, Kenwood touch screen deck, with Focal speakers all the way around, JL 12w6 and JL10w3 Subwoofers with amps, Viper Alarm with remote start, Revelco Anit Theft system, Kenwood Reverse camera, All interior lights converted to bright white led, Husky liners for front, middle, third and cargo area, Lower panels have painted to match truck, HID's in headlights and Led fogs, Mag Hytec front and rear diff covers with royal purple fluid, 08+ Tow Mirrors, Amp Research Powersteps, OEM power steering gear box, OEM all tie rod ends and drag links, OEM Hub bearing assemblies, OEM Upper and lower ball joints, New slotted rotors, New front and rear brake pads, Warn Premium hubs, Track Bar, ICON 5'' Suspension System, ICON front reservoir shock absorbers with billet reservoir clamps, Full replacement ICON Rear springs, ICON dual steering stabs, Shield American Force 22x12 Polished, Falken ATS 325/50 R22, Helwig Big Wigg Rear anti sway bar kit, Mc Nasty 2014 front end conversion kit, New 2015 OEM hood, L fender, R fender, grill, head lights & wiper cowel, 2014 F250 front bumper, Bushwacker front and rear fender flares, Hideaway bench seat mounted dual gun racks, Blue instrument panel led’s, Big four 1/0 wire upgrade, DC power 300 amp blue anodized high output alternator
Old Jan 2, 2016 | 06:22 PM
mecdac's Avatar
mecdac
Question
A quite wordy 2nd post.
How many miles on that rig?
With all those mods you might-should-have-possibly-maybe-kept a journal as a build thread, it may have been easier to follow than your post.
Welcome to FTE.
Old Jan 2, 2016 | 06:57 PM
  #28
TexPiggyPounder
Sorry I'm new to this! lol
Old Jan 2, 2016 | 08:01 PM
  #29
mecdac's Avatar
mecdac
Not a problem, welcome.
Old Jan 2, 2016 | 10:22 PM
  #30
RBerry9511's Avatar
RBerry9511
I would like to see pictures of the hideaway bench gun rack. Might be something that I need to do.
