Sponsored by: Real Truck
2012 Elocker into a 2005?
Old Dec 31, 2015 | 08:02 AM
rustybottoms88's Avatar
rustybottoms88
So my dad bought a wrecked 2012 F250 and the rebuilder replaced the rear axle. We are not sure yet why but it may of been because of a bent housing....anyway the removed axle has the OEM elocker in it. If it is still good my dad told me I could have it. My question is will the 2012 elocker fit into my 2005 F250? If so can I just wire the locker to a switch?
__________________
Jeremiah 30:17
Last edited by rustybottoms88; Dec 31, 2015 at 08:03 AM. Reason: Title clarification
Old Dec 31, 2015 | 08:09 AM
Tom's Avatar
Tom
I'm pretty sure this can be done, but it may be more trouble than it's worth. If the housing is bent you'll have to take the guts out of the differential and install it in your axle. Lots of setup involved with this, and it's generally not recommended for DIY-ers to try themselves as picky as gears can be. You'll also have to drill your housing to run the harness.
Old Dec 31, 2015 | 10:12 AM
rustybottoms88
Thank you for your reply. I guess what I really need to know is if the elocker will fit into my housing . i had been told the casting was different.
Old Dec 31, 2015 | 10:18 AM
MisterCMK's Avatar
MisterCMK
It has been done before. Let me see if I can dig up the link
Old Dec 31, 2015 | 11:13 AM
MisterCMK's Avatar
MisterCMK
https://www.ford-trucks.com/forums/8...ar-locker.html
There it is.
Old Dec 31, 2015 | 11:29 AM
rustybottoms88
Originally Posted by MisterCMK
Perfect thank you!
billyrb
Feb 16, 2018 07:40 PM
greentree ford
Mar 14, 2013 05:35 PM
mrwrench
Jan 16, 2008 12:20 AM
rprice
Apr 29, 2005 07:04 AM
