I have a '99 F250 SC with the 40/20/40 seat. I'm looking to upgrade to something with fewer tears and the integral seat belt.
I spent a lot of time searching on here and saw some threads that indicated up to a 2007 was interchangeable while one thread suggested 2010.
I'm looking for a little clarification, what is latest model truck I can swap seats with? Also, any tips or advice would be appreciated, especially with the electrical connections.
The 1999 to 2015 should be the same since the cab has not changed. It looks like you are a handy man, so you can always cut and weld the mounting system to make them work. I know the Dodge (fiat) trucks had the seatbelt built into the seat. Go to a junk yard and look around. Complete front and back seats will usually run about 500 bucks, but you need to get a new arrival since they are stored outside and the seats go bad quickly
Thank you Gatordog! I may get a little brave and try something from a newer truck.
