Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2005 Escape Electrical issue
Old Dec 29, 2015 | 08:57 PM
Powers27's Avatar
Powers27
My escape currently is misfiring on cylinder 1, have replaced all front ignition coils, but not rear yet. Was driving home today and the instrument panel stopped working, radio turned off, the airbag light came on then the battery light. Let the car sit for about 15 mins in the driveway and everything came on just fine, however if you turn a/c on max battery light comes back on. Just replaced the alternator about 8 months ago and the battery about 5 months ago. Could it be the alternator again or something else?
Old Dec 29, 2015 | 11:35 PM
scott91370's Avatar
scott91370
Very possible alternator. I had two replacements in my Tribute go out in less than a week.
Take it to an auto parts store and have them check it.
Old Dec 30, 2015 | 07:28 AM
projectSHO89's Avatar
projectSHO89
Could be a number of things, you have to diagnose it. Your symptoms are of a battery that went dead due to not getting charged.
Old Jan 2, 2016 | 06:53 AM
tomw's Avatar
tomw
You can do a basic test of alternator capacity by using a VOM connected to the battery terminals. With the engine running at idle, the voltage should be in the low 14v range.
Turn on the headlights and check again. If the alternator is working, it should be able to maintain the same voltage or near. The voltage will likely have a drop when the load is first added, but should regain the voltage after a few seconds.
Turn the blower motor on to HI, and check again. If the alternator will maintain the 14v range, it is producing enough current to run the headlights and blower at idle, and that should be more than sufficient, especially at speeds above idle.
tom
Steck804
1997 - 2003 F150
May 27, 2014 10:07 AM
sun dancer
Nov 14, 2010 12:07 PM
CATFORD
19
Sep 27, 2007 10:06 PM
98_XLT
1997 - 2003 F150
Mar 14, 2007 04:07 PM
schickgrp
Feb 3, 2006 11:42 AM
