2016 4x4 locking hub ?
Old Dec 29, 2015 | 09:52 AM
troop's Avatar
troop
Probably been answered before but I can't find it. When you shift into 4x4 using the auto mode then shift out, do you have to go the opposite direction to unlock the hubs or do they unlock automatically?
Old Dec 29, 2015 | 11:37 AM
senix's Avatar
senix
if the hubs are in the auto position then you don't need to exit the truck. Just a flip of the switch.
Locked on the hubs means the the hubs are locked in with the front driveshaft only. Your front end is turning but no power.
Still have to hit the switch to engage the transfer case and send the power to the front.
Old Dec 29, 2015 | 12:39 PM
polarlys's Avatar
polarlys
If you engage the 4x4 using the SOF feature will you see the hub indicator show it ?? What I'm saying does the hub dial physically change from auto to lock show that it has engaged or is the action contained internally within the hub. This, of course, assumes that you have not disengaged the 4x4 using the dash control prior to stopping to check.
Old Dec 29, 2015 | 12:51 PM
troop's Avatar
troop
Guys my question is if I'm using the auto feature with the hubs in auto once I'm in four wheel drive and put it back into two wheel drive do the hubs remain locked in until I drive the other direction. That is how it used to work did they change this
Old Dec 29, 2015 | 12:57 PM
senix's Avatar
senix
You don't have to drive another direction for them to disengage.
The dial on the hubs do not turn when you activate the switch. It is done internally only.
Old Dec 29, 2015 | 04:36 PM
smoky_diesel's Avatar
smoky_diesel
After going back to 2wd, the hubs stay locked for some amount of time. how much not sure. I usually back up a tire rotation just in case if I am going right onto pavement.
Old Dec 31, 2015 | 01:33 AM
kper05's Avatar
kper05
I don't back up. I can engage and disengage 4x4 from the ESOF switch moving in a forward direction without issue. There is a short delay depending on conditions of the wheels vs the information to the computer. Not sure how far back you are referencing but it was the same with the 2008-2010 SD generation. This is how it works on my brother's 2003 generation F150 ESOF 4x4 as well.
Old Dec 31, 2015 | 09:48 AM
polarlys's Avatar
polarlys
Thinking back a "few" years to when all we had was manual 4x4 systems ( ie. early Jeeps) if we tried to disengage the transfer case when it was still under tension it felt like it was stuck in 4x4. Going a bit in reverse simply relaxed that tension and allowed the shift to move much more smoothly without being yanked out of gear. I suspect that's what is happening here. The system is simply under tension in the forward direction and a short bit of rearward travel will allow the tension relax and permit the auto shifting mechanism to disengage. If you attempted to disengage with the system under tension from driving in reverse it would take some forward motion instead.
Now this is from someone with only basic knowledge of what's happening in these modern 4x4 systems. Much more familiar with the older manuals.
Old Dec 31, 2015 | 01:25 PM
2016F250's Avatar
2016F250
Is there a speed in which you should stay under when going from 2 to 4wd? Or is it safe to do on the highway if you need to?
Thanks
Old Dec 31, 2015 | 02:04 PM
senix's Avatar
senix
50-55 mph.
Old Jan 1, 2016 | 06:09 AM
troverman's Avatar
troverman
Originally Posted by senix
50-55 mph.
I have engaged and disengaged both the manual floor shift 4x4 and auto 4x4 at 70mph many times with no harm. Just be smart about it...don't engage while steering left or right, lift off the throttle when you shift, and make sure the front and rear wheels are spinning at the same speed.
The auto 4x4 system does not need to be backed up, and I found the hubs disengaged quicker than the transfer case.
Old Jan 1, 2016 | 08:40 AM
EO2SeaBee's Avatar
EO2SeaBee
This is my experience as well. Once a month, I will engage the 4x4 system on the freeway on my way home from a night shift while driving a relatively straight stretch of freeway about 10 miles. I shift into and out of 4x4 while cruise is set for 70 mph. I do this just to exercise the system and circulate lubrication.
Old Jan 1, 2016 | 08:43 AM
senix's Avatar
senix
I manually turn the hubs only once a month if I have not used the system. I will run it about 10 miles.
My concern is the hubs, not so much the transfer case.
Old Jan 1, 2016 | 08:47 AM
EO2SeaBee's Avatar
EO2SeaBee
Scott, there are occasions where I will only lock the hubs, but by engaging the transfer case on a straight stretch of freeway, I'm catching the whole system. I don't have concerns about my hubs freezing, as the number of days per year below freezing where I live can be counted on one hand with fingers to spare.
Old Jan 1, 2016 | 02:21 PM
hoseclamp's Avatar
hoseclamp
When engaging the auto hubs, you need to be stopped before doing so, once locked in they will stay locked in until you reverse direction, you can shift in and out at any speed as long and front driveline running same speed as rear, lifting throttle helps engagement and disengagement. I manually lock in the hubs 6 months a year, shifting in and out of 4wd 60-80mph is never an issue. The f150's are not comparable, the front driveline and hub assembly are engaged 100% of the time, it never stops rotating, the only difference is if it is engaged in the TC or not.
