Oil & Lubrication
best oil
Old Aug 7, 2003 | 08:51 PM
rangersvt04's Avatar
rangersvt04
best oil
ok i have decided the next time i chang my oil im gonna use a K&N oil filter but some people say stay a way from penzoil. i used it in my old van (95 plymouth voyager 3.0L 127000) it worked fine
excpt for a little valve chatter( add 1/2 quart extra and it went away). so what are your thoughts on the best over all oil for a 96 ranger 3.0L 5speed? i live in michigan ware some times you use the air and heat in the same day.if that helps for temp range
Old Aug 8, 2003 | 01:10 AM
knucklehead11's Avatar
knucklehead11
best oil
On all my vehicles in the future I'm gonna use Castrol GTX, and that's what I currently use in the BII as well. I don't even use the high mileage stuff, just regular Castrol GTX, but a thicker viscocity (20W50) since the engine has a buttload of miles. In a newer vehicle, I'd still use GTX 10W30 though.
Old Aug 8, 2003 | 11:21 AM
rusty70f100's Avatar
rusty70f100
best oil
I use Mystik JT-8 Super Heavy Duty in my truck. It seems to have pretty good specs, check here. The diesel rating means it also keeps carbon in suspension, which will keep your rings happy and your engine clean. I have seen it at sale at the local farm and fleet for $0.89 / quart, but I havent seen that price in a while, it's up to $1.60 now.
Old Aug 9, 2003 | 08:07 AM
DOHC's Avatar
DOHC
best oil
Hey ! A Mystik user !!!! It is very good motor oil .
Their 5/30 10/30 and 10/40 is great as well . It will sure take a beating
Old Aug 9, 2003 | 09:43 AM
mikemc's Avatar
mikemc
best oil
I have switched both my vehicles over to Chevron Havoline 5w30. This is the new stuff and says 'Chevron/Texaco' on the back label, not to be confused with older 'equilon' stock. It has the best cold cranking specs of any dino I've seen specs sheets for. Pennzoil and Castrol are both very good dinos as well. I like 5w30 year round with 3,000 to 4,000 mile drain intervals, this should give you the range of temp. protection you described.
Old Aug 9, 2003 | 10:45 AM
John with beastly 302's Avatar
best oil
I Use Chevron Delo 400 15W-40 in all my vehicales. I like the extra addtives and the 11.? base number. I also use it in every engine I own Big or small I've had nothing but good luck with it.
I live in the central coast CA. The averge temp in winter in the morning is about 30-40.
Old Aug 9, 2003 | 03:05 PM
dtpatt2's Avatar
dtpatt2
best oil
John, You use Delo in your 302? You like it eh? I've thought about changing to it for a long time. I just thought it was for deisels...
Old Aug 9, 2003 | 03:39 PM
JustinH's Avatar
JustinH
best oil
Just stick with the motorcraft oil filter, and i like mobil1 for the newer cars.
For an older car, I like castrol GTX
Old Aug 12, 2003 | 12:17 AM
Texan1983's Avatar
Texan1983
best oil
just use good old valvoline. Max life is good for an older engine, for the seals. pennsoil and quaker state are crap oils, they have a high ash content that cause it to become waxy and build up in the motor. valvoline has been the best for me.
Old Aug 12, 2003 | 09:30 AM
jimandmandy's Avatar
jimandmandy
best oil
"Its not just for diesels anymore". API SL rated in addition to the diesel ratings. Just do it.
Jim
1994 F-150 4x4 302 E4OD
Old Aug 15, 2003 | 08:40 PM
thecarman's Avatar
thecarman
best oil
I'd use good ole Valvoline or if you like synthetics, run Mobil 1. K&N is a good choice for an oil filter.
Old Aug 15, 2003 | 08:49 PM
13hondacr250's Avatar
13hondacr250
best oil
Wix filter and mobil 1, 0w30 in the cold winter for my gasser. delo for my PSD. nuf said
buzo-ech
Escape & Escape Hybrid
Aug 9, 2016 09:02 PM
Supercab
1983 - 2012 Ranger & B-Series
Sep 23, 2015 05:32 AM
PSD6litre40
Dec 26, 2013 06:42 PM
veggieford
64
Jan 14, 2010 02:33 PM
Beachbumcook
Jun 6, 2007 12:27 PM
