Engine pulleys
Old Aug 7, 2003 | 08:28 PM
UglyBeast's Avatar
UglyBeast
Question Engine pulleys
I just got a reman 351W for my 81 f-150. I ordered a milodon high-vol alum water pump from summit. The problem I ran into is that my water pump pulley and crank pulley have no gap between them! All parts bolt up, except the water pump pulley won't go on because it hits the crank pulley. I don't know if the motor I took out is an older motor or not. Did they make different diameter pulleys for different years?
