Carpet vs bed liner
Old Dec 24, 2015 | 12:40 PM
Django.Amadeus's Avatar
Django.Amadeus
Carpet vs bed liner
Any advice on replacing the interior carpet with sprayed on bed liner and some drain plugs?
1977 f250 4x4, 400m.
Old Dec 24, 2015 | 07:30 PM
Blue and White's Avatar
Blue and White
I've seen some threads with nice pics if that is what you like. Like any coating key would be prep. Clean, repair and prime first then the coating. You could weld in a short length of the correct diameter tube and use some bilge plugs for a boat in the hole.
Old Dec 25, 2015 | 12:46 AM
DirtyLarry's Avatar
DirtyLarry
I can tell you from experience of cleaning my bedliner out in my truck that simply running water over doesn't get the dirt out. I have to spray it with my thumb over the nozzle to do anything and then it's still dirt filled in nooks and crannies. If you did that in the cab you'd get water all over the place.
It will also get hot and be louder in the cab. I decided to go with carpet after a lot of research and thinking.
Old Dec 25, 2015 | 06:41 AM
Damifiknow's Avatar
Damifiknow
Lizzard skin and carpet on top IMO.
Old Dec 25, 2015 | 09:00 AM
Hyperactive460's Avatar
Hyperactive460
any thoughts on this ? been thinking about it for my 78.
http://www.lmctruck.com/icatalog/fc/865w/0063.jpg
Old Dec 25, 2015 | 10:38 AM
78 PEB's Avatar
78 PEB
Personally, I'd rather put the bedliner on the underside of the cab as an undercoating. Then carpet or rubber mat inside......just my opinion......
Old Dec 25, 2015 | 10:36 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
If you do use spray in bedliner in the cab make sure you 100% want it, because you will not be as easy get it out later. X2 it is all in the surface prep.
A vinyl floor over some dyne mat or topped off with carpet will take care of a lot of the road noise. And make it warmer in the winter.
If it is off roader/mudder only, do it and never look back. Do the cab behind the seat 1/2 way up, both sides of the cabs kick panels and even the bottom of the doors below the door panel bottom line, rockers and 1/2 up the B pillar.
Old Dec 25, 2015 | 11:47 PM
mnutw3's Avatar
mnutw3
I agree with 77&79F250, I did spray on insulation then bedliner underneath the cab and spray in bedliner on the inside then dynamat style adhesive insulation and topping it off with insulated carpet. In case you haven't picked up on it I was trying to get a quiet ride... Didn't work as much as I was hoping. In retrospect I'm glad I used the bedliner inside and out- the floor had zero rust and I'd like to keep it that way. If you plan on lots of water crossing or mudding and you're not looking for a quiet comfortable DD then I definitely would not recommend carpet.
Old Dec 26, 2015 | 05:05 PM
Dirtbag's Avatar
Dirtbag
I did the roll-on liner, on the interior floor boards some 15 years ago in my '78 4x4 wrecker. No carpet/no regrets to this day. Still looks just as good after all these years yet, even with chains, J-hooks, block & tackles and clevises thrown on them. It's a 100% no frills work truck though, not a cruiser.
Hardy1960
2015 - 2020 F150
Feb 9, 2019 11:24 AM
Thurter
May 12, 2017 06:26 AM
drfelgood5
Oct 25, 2008 07:38 PM
Hellbore
May 11, 2006 10:46 AM
afinepoint
Paint & Bodywork
May 20, 2004 10:46 AM
