Electric fan conversion
Old Dec 24, 2015 | 02:21 AM
adampeel85's Avatar
adampeel85
Who has done an electric fan on there truck. I have the 390.
I remember when I had a foxbody everyone went to the j-yard and took the dual fan assembly off a V6 ford contour and it fit overy the radiator very well.
Anything like that you guys are doing with these trucks?
Old Dec 24, 2015 | 01:31 PM
ZarK-eh's Avatar
ZarK-eh
Yup!
There are a few guys that did the fan conversion from various ford cars/vans. I went a different route than most and tied mine onto the EFI to control on/off at the temps I wanted. AFAIK, there is a nifty Volvo fan relay and temp sensor switches to do the same thing.
My '78 300 i6 with VEMS EFI:
Old Dec 24, 2015 | 07:38 PM
HIO Silver's Avatar
HIO Silver
For Bumps an dDents, the typical donors include the twin fanned Taurus/Contour fan and the monstrous two-speed Lincoln Mark VIII fan.
My setup is Mark VIII, custom brackets, Volvo relay, all controlled by an Edelbrock E-Street EFI.
The Edelbrock ECU provides two low-voltage ground signals at customizable temperatures for each fan speed (or individual fans). Based on the Volvo relay schematic, only one relay is engaged at any one time (high or low speed) which explains why it only has one power feed.
I merged the Volvo relay harness with the Lincoln Mark VIII plug, fabbed up some weather pack connectors for the fan signal wires, and fabbed up an aluminum bracket. I adjusted the low fan speed to come on at 195° and high speed at 210°.
Mocked up with custom brackets:
Here are some threads and sites for your information....
Electric Fans/Cooling Upgrades
Ford Muscle: Lincoln Mark VIII Retrofit
Fordification Thread: Lincoln Mark VIII/T-bird Two-Speed Fan Installation
Pro-Touring.com Thread: Mark VIII fan & SPAL Controller
Hollister Road Electric Fan Components
The Fan Man - Electric Fans & Controllers
Nasty Z28 Thread: Budget Dual Electric Fan Controller Set Up
FTE Thread: akforceten's 1972 F250
Centech Fan Controllers
FE Clutch Fan Installation: Hayden 2710 & Derale 17118
Old Jan 25, 2016 | 06:57 PM
Choppermike's Avatar
Choppermike
Was the Volvo setup a junkyard item?
Old Jan 25, 2016 | 07:39 PM
HIO Silver's Avatar
HIO Silver
Yes.... just the relays, relay plugs, and as much of the wiring from them I could grab.... better too long that too short!
They usually hide under the core support near the right headlight.
Old Jan 25, 2016 | 07:50 PM
Choppermike
Awesome thanks, Thats a clean looking install. I assume I will need some sort of controller also? Correct?
Old Jan 25, 2016 | 09:07 PM
HIO Silver's Avatar
HIO Silver
Yes, either two temp switches and relays or some sort of solid state controller.
My rig is equipped with Edelbrock's E-Street EFI and it can control two fans or a single two-speed fan at whatever temperature is selected through the software in the tablet.
An option is a PWM controller made by Hayden. I'd hit up Hollister Road for more info on what is available.... including a section of radiator tube with two bungs for temp sensors.
Here is a link posted by a fellow member to various wiring diagrams: http://www.davebarton.com/pdf/coolingfandiagrams.pdf
Old Jan 27, 2016 | 07:49 AM
Choppermike
I looked up the Hayden PWM controller. It looks like a great option. I have a question though, it appears that it controls the speed of the fan so this is not exactly a 2 speed controller but a variable speed controller? Am I correct in that? If so that looks like thats the one to use.
Old Jan 27, 2016 | 08:25 AM
HIO Silver's Avatar
HIO Silver
Yes... fan speed would be dependent on coolant temp.
caliRangerXLT
May 13, 2018 10:37 PM
Curated Content Editor
General Automotive Discussion
Jun 7, 2017 01:20 PM
Tony Greene
Aug 9, 2016 02:56 PM
tabascom16
Jan 19, 2015 06:48 AM
bghnkinf250
Feb 4, 2010 09:24 PM
